Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Collinite 845
  1. #1
    Junior Member Rsofa's Avatar
    Join Date
    Jun 2009
    Location
    Long Beach,Wa.
    Posts
    36
    Post Thanks / Like
    Collinite 845
    So is this a wax or a sealant???? I will be ordering a buffer kit and a few other things along with it ( if and when they have the next no exclusions sale)and would like to try the Collinite 845 if this is a last step what would be a good sealant to use first???? I am leaning towards the Griots buffer but they are on Back Order anyone know what's up with that?
  2. #2
    Super Member lawrenceSA's Avatar
    Join Date
    Feb 2012
    Location
    Durban - South Africa
    Posts
    1,713
    Post Thanks / Like
    Re: Collinite 845
    As far as I know it is a hybrid.
    It should work well enough on its own in terms of protective abilities. Over here in South Africa I will typically see 4 to 6 months out of it.
  3. #3
    Super Member wdmaccord's Avatar
    Join Date
    Jun 2013
    Location
    West Des Moines, IA
    Posts
    1,278
    Post Thanks / Like
    Re: Collinite 845
    Quote Originally Posted by lawrenceSA View Post
    ^^This
    2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
    2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
    2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
  4. #4
    Join Date
    Jun 2009
    Location
    Long Beach,Wa.
    Posts
    36
    Post Thanks / Like
    Re: Collinite 845
    So basically I could do the correction needed and follow up with the 845 and call it good??
  5. #5
    Super Member Klasse Act's Avatar
    Join Date
    Feb 2012
    Location
    Palatine Illinois, USA
    Posts
    24,781
    Post Thanks / Like
    Quote Originally Posted by Rsofa View Post
    Absolutely!
    If you want, apply a 2nd coat the next day. This is, hands down, one of the easiest to apply and even easier to remove products on the market, period! Take the cap off, place you applicator pad over the top and flip upside down, leaves a spot the size of a dime and that amount will go a long, long way!
    2022 Elantra N Cyber Gray
    Some say..."He likes Swedish fish because they're made with caranuba wax"
  6. #6
    Join Date
    Feb 2012
    Location
    Posts
    1,713
    Post Thanks / Like
    Re: Collinite 845
    Can't see any reason why not.
    I have followed that route on many vehicles, all without issue.
    Read through this for more info on the product
    http://www.autogeekonline.net/forum/...ndary-wax.html
  7. #7
    Regular Member
    Join Date
    Jul 2014
    Posts
    135
    Post Thanks / Like
    Re: Collinite 845
    Its bottle call it insulator wax. Easy to apply and easy to clean. Collinite 476s is more durable and detergent proof, but its difficult to apply. LSP for sure. Apply thin.
  8. #8
    Super Member mwoolfso's Avatar
    Join Date
    Jul 2011
    Location
    Long Island, NY
    Posts
    2,592
    Post Thanks / Like
    Re: Collinite 845
    Quote Originally Posted by Swift View Post
    If you apply 845 properly then 476 would be just as smoothe.
  9. #9
    Super Member Desertnate's Avatar
    Join Date
    Aug 2013
    Location
    St Louis metro (Illinois)
    Posts
    5,855
    Post Thanks / Like
    Re: Collinite 845
    Ditto.
    I did the same. Last winter a single coat of 845 on my daily driver lasted 6 months through the worst winter we've seen in decades. I also just used a glaze rather than correcting and it still lasted that long. Some here worry about glazes shortening the lifespan of the LSP applied on top.
    Drop by to see the latest at The Car Geek Blog
  10. #10
    Join Date
    Feb 2012
    Location
    Posts
    24,781
    Post Thanks / Like
    Re: Collinite 845
    Ok, listen I'm not raggin' on any one person here, even though its been mentioned once again but I have used all 3 of the Collinite triplets in different ways and have NEVER, EVER had an issue applying it and more importantly REMOVING IT, PERIOD! I know alot of bad info can go out on a forum like ours here but this has been a theme that comes up all the time and its just not true. I have applied both #476 and #915 per the directions and had NO issue removing it. I then applied both product to the car from start to finish and THEN removed, again, NO ISSUE WITH REMOVAL! I then applied both products to the car and left it on the car for an entire day, then removed it and guess what, NO ISSUE WITH REMOVAL! Now just to be clear here, I removed each seperately, not together, I know it reads like this but that's not the case, 3 different methods with each products, so I consider myself to be pretty knowledgeable with Collinite and all this talk about #476 and #915 being hard to remove just isn't true and I wish it would stop because all its doing is keeping people from trying 2 of the best products on the market, period!
Similar Threads
  1. Replies: 16
    Last Post: 05-14-2018, 03:44 PM
  2. Trade: Collinite 476S for Collinite 845 IW
    By SilverJag in forum Auto Detailing 101
    Last Post: 05-26-2016, 11:59 PM
  3. Replies: 3
    Last Post: 02-09-2016, 07:18 PM
  4. Replies: 55
    Last Post: 05-21-2015, 08:12 PM
  5. Replies: 38
    Last Post: 05-06-2013, 07:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
