Dislikes: 0
Problems with Meg's 105
I have Meg's 105 and 205. I've used them both on both of my cars. I've used the 105 with an orange pad, but it always seems to dry out / clump up on me. I don't have that problem with the 205, that works well. I have a Flex 3401 DA, start of on speed 2, then once I have the specified area covered, I move to speed 4. Any advice?
Thanks,
Steve
Re: Problems with Meg's 105
105 works VERY quickly and typically begins to dry out/dust on me starting the 3rd pass. 205 has a longer work time.
If it's clumping on you I would suggest cleaning your pad more frequently or changing pads.
Will spritzing the pad with water help any??
Super Member
one reason i enjoy working with 4" pads more than the bigger pads b/c on curevd surfaces, you dont throw as much dust or clumps off the pad.
17 Tucson | 2015 Mustang Ecoboost Premium PP | 89 Kawasaki Ninja ZX-10
@TheRealPolisher on FaceBook | @green2kgt on IG
From my experience no... It'll make it worse. 105 like a very dry pad from what I've found. you're best bet is to clean/change pads more frequently.
I haven't experienced a lightly dampened pad making 105 worse, but I also haven't noticed it cutting down on dusting much (if at all). It's just the nature of the beast.
Super Member
Regular Member
I'm a noob with 105, but with a 5.5" pad I've done my entire crew cab F250 longbox using 105 and a very light spray of distilled water for the 4,5,6 passes (when needed) No issues and the truck looks like a million bucks. 105 followed by 205. Speed 6 right from the get-go. Griot's DA
That must've taken forever to go over an F250 with 5.5" pads. Well done, ha ha.
Edit- oh, and another thing to try if you are not getting enough work from it on a section is to reduce the size of the area that you are working. Instead of doing a 2'x2' area try doing a 16"x16" area or something like that.
Regular Member
Not too bad, really. Tailgate was 30 minutes, pass side (no hood) was 2.5 hours and driver side with hood was about 3.25 hours total including sealing. I have the roof left now...maybe 30 minutes and I'm done. I did 4-6 passes of 105 then 205 over the entire truck. My shoulders are still sore.
Similar Threads
By pmg in forum Off-Topic
Last Post: 12-26-2013, 01:40 AM
By 1carguy in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 04-17-2013, 08:12 PM
By pointillistic_practitioner in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 12-04-2011, 03:24 PM
By Integra-S in forum Auto Detailing 101
Last Post: 06-04-2010, 01:35 PM
By nrengle in forum Auto Detailing 101
Last Post: 01-06-2009, 02:11 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
26 | 27 | 28 | 29 | 30 | 31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
