Dislikes: 0
The new mf polishing pads?
I've heard of these mf cutting polishing and finishing pads. But know nothing of them. I just got a PC and I need all new pads. Can I use these mf cutting pads with uc for heavy cutting? How r they different from foam pads other than not being foam..
Also I just booked a deal with a dealership to do all their trade ins so with my new 6 in PC I'm prolly going with a 5in backing plate but how many and what pads should I get to keep me going for a while at least a month or so?
Would the new mf pads be good due to them being easy to machine wash?
As much info as u have any and all please help.
Sent from my SCH-L710 using AG Online
Re: The new mf polishing pads?
All I use is MF pads unless I run into some soft paint. I love them. I used to be a 100% rotary guy until I tried MF pads on a da. That rotary has only been used like twice in the past 3 months. They cut harder and faster than foam pads. Foam finishes nicer. I've never used ultimate compound with them, but I'm sure it would work fine. I generally use 105 & 205 with them.
I clean mine by hand. I soak them in dawn dish soap and water for a few hours. Then I rinse them in the sink until the water squeezed out is clear. I spin them on my rotary to get out excess water. I generally use 1 pad per half of the car. I blow the pad out after each section I work. I'd get a few of each to start for sure
Also will the backing plate that comes with the starter kit megs has work on a PC?
Thanks for that info.. how many different mf pads do they have I've only seen the cutting and finishing.
Also u say foam finishes better. Would it be good to do polishing or cutting with the mf pads then finish with foam?
And are they a better value than foam? Like due to the fact they're easy to clean and, do they last longer? Like I could get more jobs done with the mf pads vs foam pad?
Originally Posted by HardLineDetail
What in the world does that have to do with mf pads?
I have no idea how i ended up in this post lmao
Ha.. OK.. but back to mf pads. Are there more than just the cutting and finishing ones? And do the offer a better value than foam? Like last longer, work better...
Anyone maybe have a pros and cons on foam vs mf pads?
Super Member
MF pads cut better than foam pads so they save time. I only use foam pads for finishing polish. The biggest thing for me is I can use 1-2 MF pads for one car as for foam pads would take me 5 or more pads to do one car.
When using MF pads then need to be clean often by using a pad brush or using compressed air it what I use. I don't know why people say don't use MF pads on soft paint I do all the time with great results.
Ive only seen cutting and finishing except i believe lc makes only one pad for both. The only problem I have with them is they will marr soft paint. Some paints I just can't get them to finish perfectly. The only time I use foam pads is for finishing.
I have polished 25+ cars with a set of 2 each and they are still going strong. I have tried meguiars and optimum MF pads and like the meguiars better. The optimum cutting pad I have failed after 2 panels.
Similar Threads
By Joe@NextLevelDetail in forum Auto Detailing 101
Last Post: 06-26-2019, 06:14 AM
By coupe07 in forum Wool & Foam Buffing Pads
Last Post: 05-15-2015, 08:21 PM
By Dogfather in forum Auto Detailing 101
Last Post: 08-21-2013, 08:44 AM
By WRAPT C5Z06 in forum Wool & Foam Buffing Pads
Last Post: 02-17-2010, 10:45 PM
By Justin in forum Auto Detailing 101
Last Post: 07-19-2008, 07:30 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
26 | 27 | 28 | 29 | 30 | 31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
