Results 1 to 10 of 10
  1. #1
    Newbie Member
    Join Date
    May 2019
    Posts
    7
    Post Thanks / Like
    Real benefits of 5" backplate on 21mm throw?
    I have a Griot's G21 and I see that many people switch their backing plate to 5" on the 21mm long throw. Is there really some technical benefits of doing so?
    Note that I also have a GG6 with 5" plate and a GG8 with 3" plate.
    I am covered when I get to tight spaces. I just want advices on using the G21 to it's full potential.
    Thanks
    Sent from my SM-G965W using Autogeekonline mobile app
  2. #2
    Super Member 2wookies's Avatar
    Join Date
    Jul 2015
    Posts
    367
    Post Thanks / Like
    Re: Real benefits of 5" backplate on 21mm throw?
    I too have the G21 and was using the 6” backing plate for 2 years. Once I made the switch down i wished I’d done it right away. 5.5” pads cut quicker, the 21mm throw helps cover more area quicker so team that with a smaller pad and you’re rocking.
  3. #3
    Super Member Eldorado2k's Avatar
    Join Date
    Nov 2015
    Location
    Los Angeles, California
    Posts
    13,835
    Post Thanks / Like
    Quote Originally Posted by 2wookies View Post
    This is how I like to think of things except I use a 6” backing plate.. I’ve also had the 5” backing plate since the 1st day I bought the polisher but rarely use that setup, only slap it on if I’m dealing with a smaller vehicle or some extremely hard paint.
  4. #4
    Super Member WillSports3's Avatar
    Join Date
    Jun 2016
    Location
    Toronto, ON
    Posts
    1,453
    Post Thanks / Like
    More cutting power. On some cars that only needs a one step, I vary between 2 to 4 passes. Then when I compound, three to four instead of five or six passes. On my own cars that are kept pretty well maintained, I'll literally throw on a dot or two of polish amd do two passes and it's done.
    2016 Mazda 3 Sports GT
    2015 Lexus IS250 F Sport
  5. #5
    Newbie Member
    Join Date
    May 2019
    Posts
    7
    Post Thanks / Like
    Quote Originally Posted by WillSports3 View Post
    Thanks for the reply.
    So, it cuts more with the 5 inch plate, but does it finish as good or better than the 6 inches plate?
    I sure could appreciate working faster with the 5 inch, but I imagine that one has to be careful of not damaging the paint with that extra cutting power.
  6. #6
    Join Date
    Jun 2016
    Location
    Toronto, ON
    Posts
    1,453
    Post Thanks / Like
    I think that it finishes absolutely great. Depends on technique for long throw. I cut at around 4 to 4.5, and if I'm polishing I'll polish at the 3.5 to 4 mark.
  7. #7
    Super Member PaulMys's Avatar
    Join Date
    Jan 2014
    Location
    Eastern L.I. NY
    Posts
    10,772
    Post Thanks / Like
    Quote Originally Posted by Abic View Post
    And this is the key.
    Just like any other tool, or anything you do really, practice develops technique.
    You can only read so much before you have to take that plunge into the actual "doing".
    It is no coincidence that man's best friend cannot talk.
  8. Thanks Thomkirby thanked for this post
    Likes oneheadlite liked this post
  9. #8
    Join Date
    Jun 2016
    Location
    Toronto, ON
    Posts
    1,453
    Post Thanks / Like
    It's very true. Right now I'm working on cutting at 3.5/3. Less heat better cut. Less heat, less paint expansion, and therefore truer actual cut.
  10. #9
    Newbie Member seanktm's Avatar
    Join Date
    Nov 2020
    Posts
    11
    Post Thanks / Like
    Did you notice any increase in vibration when you made the switch from 6" to 5" BP?
  11. #10
    Join Date
    Nov 2015
    Location
    Posts
    13,835
    Post Thanks / Like
    It has the ability to cut harder with the 5”, but that doesn’t necessarily mean you’ll work faster, because you’ll be able to cover more ground and work faster with the 6” backing plate.
    In reality, the chances of you needing to equip your polisher with a 5” backing plate because the 6” can’t quite cut though the defects are slim.
    I polished this car yesterday. The only reason I used the 5” backing plate on my G21 was because it was already on there and I was too lazy to go grab the other 1 and change it.
    Before
    After
  12. Likes Caraman, PaulMys liked this post
Similar Threads
  1. LC 4" backplate quality
    By 11B250 in forum Flex Polishers
    Last Post: 04-28-2023, 09:19 AM
  2. 8mm throw + 10mm - 12mm - 15mm or 21mm
    By 2shiny in forum Auto Detailing 101
    Last Post: 10-16-2017, 08:04 AM
  3. What are the REAL benefits of a long throw polisher?
    By briarpatch in forum Ask your detailing questions!
    Last Post: 04-12-2016, 04:41 PM
  4. Replies: 30
    Last Post: 11-25-2014, 05:20 PM
  5. 21mm throw DA recently available in Brazil
    By Tato in forum Auto Detailing Tools and Accessories
    Last Post: 11-06-2014, 12:34 PM
Members who have read this thread: 1
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
