I have the regular iron x which does a good job, however I have some questions. If I wanted to make my product go further can I dilute the spray? Should I buy the 500g paste if I am doing multiple cars?
Bill 1234
2004 audi a6 quattro (traded).
2015 Ford Escape 2.0l ecoboost 4WD
don't dilute the spray but you can dilute the paste. someone posted about this a couple days ago. search "ironx plastidip" to see the thread. I believe he diluted 1:4 with the paste and still had great reaction with the iron particles on the wheel.
diluting as I mention would of course be for spraying. the paste alone is already economical in that you can use a little on the paint and wipe it around vs. spraying the car down.
good point. I used Iron x spray on my personal vehicle and it worked well, just expensive. Might try the paste as i get more for the 20 bucks
Bill 1234
What I do is while wearing a rubber glove I will put some x on a couple fingertips and spread all over the wheel, let dwell and hit it with a little brush and rinse. I have not tried x on a panel yet, but will use a applicator.
Steve
-The Titanic Was Built By Professionals But The Ark By Amateurs-
In some instances Iron X will remove the majority of contaminates so you may not feel the need to clay afterwards.
In almost every instance (at least in my case) Iron X has made the surface contamination go from poor to decent, so a quick claying was all that was needed instead of an extensive claying.
Bookmarks
