Dislikes: 0
Optimum Hyper Polish: Difficult to remove? Anyone else have this problem?
I've used Optimum Hyper Polish on several cars so far as a finishing polish, but have never understood why it is such a difficult polish to remove afterwards?
I've done a couple of Jet black cars recently. One was a super soft Lexus. Today I used it on a jet black Aston Martin with harder paint, but I noticed on both cars the HP residue is very tough to remove.
Other finishing polishes like M205 and Sonax Perfect Finish are a breeze to remove after you're done buffing.
Just wondering what am I doing wrong or is the polish just difficult to remove no matter what?
Super Member
Re: Optimum Hyper Polish: Difficult to remove? Anyone else have this problem?
Dear,
Never used the polish you're talking about, but I had hard time earlier with other products, that tweaking technique a bit made the same products a breeze to remove.
One example is Uber Compound. I've noticed that not priming the pad the conventional way (but using a fine mist of detailing spray), and using 3-4 Dime drops to start, and then 3-4 pea size to keep moving on, helped very much.
Another point was that I wasn't working the product for it's entire cycle, so trying to remove 'un-worked' polish is harder than when you definitively brake the abrasives down.
So, 'defining a prime the pad technique', use less product and work it for more time (or slightly slower arm speed, or more polisher speed, or more pressure) are my 0.02$.
Maybe you just have to work it differently that you're adapted with M205 or PF.
Hope I've helped,
Kind Regards.
“Nature is pleased with simplicity. And nature is no dummy”
― Isaac Newton
Super Member
I used it twice and found it very easy to remove.
Try this, once your done polishing hit it with a light mist of DS and simply wipe it off.
Chris from Optimum says a damp microfiber should take off the residue.
Since its a no-fillers no-oils product, using a QD might defeat the purpose.
Ive had a similar issue with a different water based no fillers/oils product (Gtechniq P1). Seems like I had to work it MUCH longer than standard products before it was ready to come off and even then it wasnt the easiest to remove.
I know, it seems completely counter-intuitive....use it on soft paint because it "finishes down nicely" then risk marring the paint having to power off the residue. Thats actually the reason I took my car to a pro, it seemed like I could polish a panel perfectly but the second I tried to remove any leftover residue it would introduce marring.
Super Member
Sounds like too much product or you are working it improperly. Hyper polish is a breeze to remove most of the time.
Sent from my DROID RAZR using AG Online
What speed were you using?
I've found that at higher speeds, it dries out fairly quickly. In my experience, it works best at speed 4-4.5 on the Rupes 21.
Definitely not too much product. I have tried many different approaches with this specific product. I am just not liking this product. I don't want to resort to using QD to remove polish residue, that's crazy talk.
Super Member
I always found it super easy to remove. Too much, too little, overworked.... It is just a breeze to remove for me no matter what. Maybe your bottle is old and dried out. Or maybe there is a problem with the towel/towels you are using to remove it
Super Member
Were the vehicles clayed/decontaminated prior to polishing? How about surface temperatures?
Maybe I will give it another shot, but I do not see having a different result. I used a brand new towel and it was a major PITA to remove the HP. I tried the same exact thing with several other polishes on the same car and none were difficult to remove.
Absolutely, everything was clayed and decontaminated. That's not the issue, note that I said other polishes were working beautifully on the same exact car(s), the issue was strictly with the HP. All cars are done inside the shop with about 55-65 degree temperature.
Machine is a 3401, pads were either LC white or crimson.
Similar Threads
By Dan Tran in forum Auto Detailing 101
Last Post: 12-21-2019, 10:12 PM
By Harry Da Hamster in forum Auto Detailing 101
Last Post: 11-16-2018, 02:58 PM
By Conway9 in forum Auto Detailing 101
Last Post: 03-10-2013, 06:19 PM
By Mister B in forum Show N' Shine
Last Post: 12-31-2010, 12:08 AM
By Anthony Orosco in forum New Car Care Products
Last Post: 04-25-2010, 04:42 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
26 | 27 | 28 | 29 | 30 | 31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
