Dislikes: 0
Super Member
Bleach white tire cleaner
I noticed someone using this product and was just wondering,wouldn't this stuff eat up our tires over time due to the fact it contains bleach?
Super Member
Re: Bleach white tire cleaner
I use it all the time to clean the raised white letters on my tires. I just replaced the original tires on my 03 truck. So 9 yrs worth of use with no issues.
Super Member
Awesome thank you for the feed back, I'll have to give it a try, I did notice that it really cleans tires very well.
Super Member
Sometimes it's difficult to discern what's really in a product.
MSDS's for: WESTLEY'S BLECHE-WHITE:
I.
Ingredient/Component ………………………………CAS#
Isopropyl alcohol………………………………………67-63-0
2-butoxyethanol……………………………….……..111-76-2
Linear alkylaryl sulfonate….…………………..25155-30-0
Sodium silicate……………………………………….6834-92-0
Water………………………………………………………7732-18-5
II.
2. Component Information
Component..................................................CAS#
Isopropyl alcohol........................................67-63-0
Butyl cellusolve........................................ ..111-76-2
Surfactants....................................... .........(Mixture)
Sodium silicate.......................................... .1344-09-8
Water............................................. ...........7732-18-5
Dye............................................... ............(Mixture)
__________________________________________________ __________________________________________________
Question:
Do you see any ingredients listed on these MSDS's that could be considered a "Bleach"?
Is "bleach" either an acid or a base (alkaline)...Or both?
What is the ph value of 'common bleaches'
Can a bleach be an oxidizer, a reducer...Or both?
Yes...I've used Westley's/Black Magic's/Sopus' Bleche White many times...
-Not saying that this product is detrimental to a tire's longevity, or not...
Never personally observed/studied/tested the above chemicals/ingredients affects on tire rubber-formulas.
-Neither have I done so on today's modern-tires whose formulas do not contain much natural rubber, if any.
RE: Westley's Bleche Concerns:
I would be more concerned about never allowing this product to ever come in contact with:
-Magnesium or bare-aluminum wheels
-Painted or glass-surfaces
-Any non-rubber items
-Personal eyewear, clothes/fabrics
"Be wary of the man who urges an action in which he himself incurs no risk."
~Joaquin de Setanti
Super Member
I use bleche white every so often and have had a bottle for a couple years. I just ran out so I picked up a new one. Did they change something? It does not seem to work like my old bottle did. I did my normal routine, but it just seemed to sit on top of the tire. Either they changed it or I bought a bad batch because it did not work well at all. I just wanted to see if others had this issue.
Been using it for many years, but yes, the last bottle I bought smelled completely different than anything from the past. I don't think it is as strong as it used to be.
I have started using other apc's recently though, so I haven't used it in some time.
Similar Threads
By Mike Phillips in forum Product Reviews by Mike Phillips
Last Post: 08-05-2020, 01:47 PM
Last Post: 04-15-2020, 04:21 PM
By Klasse Act in forum Off-Topic
Last Post: 12-30-2018, 10:11 PM
By Justin at Final Inspection in forum Product Reviews
Last Post: 03-01-2016, 09:49 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
