Dislikes: 0
Super Member
Menzerna, and sealant Q's.
Hey, I want to try some menzerna polish. My EVO only has minor swirls. And the clear is quite soft.
I want to use a sealant after. I was looking at the DG 101 or the DP sealant.
Has anyone used these sealants w/ menzerna? Results?
Should I go w/ the Micro Polish or the nano polish? Do the both have the same cut and finish properties?
Thanks, Mike
Super Member
check out the menzerna chart at the top of the page at ag for menzerna. my suggestion would be the 106ff followed by either the glaze (if you want supreme results)and/or the sealant. I think there are some threads about the DG following Menz. I think hte 105 is the sealant you want to try however.
Super Member
Is the 106ff only to be used on scratch resistant clear coats?
I dont want a ultra durable sealant. Must hide my paint color.
I have found that a 3-6 month seal looks better w/ Liquid Souv.
Anyone try the DP?
Super Member
The DP Sealant is great. I've only used it once but will not hesitate to use it again. It darkened the paint a little and had a slick, wet look.
Super Member
106FF would be a natural for a little harder coat, since its soft play it safe and use the Final Polish. Never heard of any sealants failing to cure to FP so it should be a perfect offering.
Super Member
Thanks guys, I ordered the FP, DG101 and polyclay.
Killr, whats the diffrence between Micro, and FP? Have you used both? If so, in your opinion, with one finishes better?
SELF BANNED
I use WG over Menzerna all the time without any problems.
wow...confusion. just when i thought i understood everything i realize i dont. i understand that there can be compatibility issues with glazes and sealants and glazes and waxes but i had no clue there could be compatibility issues with polishes and sealants and polishes and waxes. that does not make much sense to me considering polishes are meant for correction.
Super Member
the menzerna ceramiclear polishes are just as safe to use on regular clears as they are on ceramiclears...if using them on regular clear coats they just do the work faster and with fewer passes..106ff (nano polish) is by far the best all around polish..very rarely do you need to use anything else...
It's because some polish contain oils, and that presents a bonding problem for sealants more than they would for waxes
Best thing to do is a 50/50 wipedown before you're to apply the sealant
-Goose
2007 Avus Silver Audi RS4
2018 Black Redline Edition Chevy Silverado
Similar Threads
By edgar sanchez in forum Wolfgang Car Care
Last Post: 06-15-2016, 08:34 PM
By Swift in forum Ask your detailing questions!
Last Post: 10-11-2014, 07:56 AM
By FourEyes45 in forum Ask your detailing questions!
Last Post: 12-02-2011, 03:19 PM
By Old Tiger in forum New Car Care Products
Last Post: 04-09-2010, 05:48 PM
By arkus in forum Product Reviews
Last Post: 01-19-2010, 06:30 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
