Dislikes: 0
Fluid Damage?
Hello, my name is David and I own my own detailing business as many of you do. I recently detailed a 2011 Mercedes Benz GL450, about two days after the detail was completed he comes back to me and claims that his door lock is broken(internal, wont unlock) and his Vent is broken. I explained to him that the vent was already broken and that I have documentation of it being broken before the service began, I then stated that I understand and recommended him to take it to a mechanic and get it inspected to see what the cause was. He replies back about 3 days later that he had the vehicle serviced at a dealership and told them that he believes its fluid damage. I have washed a lot of cars, owned a few and done interior details on many. I have never heard of a lock short-circuiting after a detail. So today I called over 21 mechanics across the country(I will call more over the weekend) to get the most diverse answer possible, 1 gave no answer, 2 said that it is very possible, 12 said that its EXTREMELY unlikely but anything is possible and 6 said that it was impossible. Now I am willing to pay for what is broken, as much as it sucks. I just want to make sure it's actually my fault, it totaled up to $800.00 to fix it, he says he has the lock apparently so I haven't seen for myself if there are A. Burnt wires or B. corrosion, Any ideas or help would be greatly appreciated.
Super Member
Re: Fluid Damage?
If you google GL450 Door Lock Actuator, you get enough hits for it to be apparent it’s a pretty common problem for that car.
As a technician (independent BMW and Audi), unless you were pressure washing at the door lock, I find it hard to believe it was anything you did. Are there any independent Mercedes shops near you you could get a second opinion/price quote? We’re generally a lot cheaper than the dealer.
Post Thanks / Like - 0 Thanks, 2 Likes, 0 Dislikes
Re: Fluid Damage?
Its out of my hands and already was repaired through a dealer. It was also an interior detail the most aggressive thing i used was a steamer but i quickly brush over the door with it to loosen up dirt then i quickly wipe up as much moisture as possible. He claimed the door was ratteling and wouldn't open. I believe the mechanic wrote it up as fluid damage but im not 100% sure. Im just in disbelief.
Re: Fluid Damage?
The mechanic wrote it up as, cleaning fluid may have shorted the lock.
Super Member
Re: Fluid Damage?
If this is truly the case, I'd have serious reservations on buying a MB of that model.
"Why are my door locks inoperable?"
You washed it.
It is no coincidence that man's best friend cannot talk.
Re: Fluid Damage?
Interior Detail, i apologize for not specifying.
Super Member
Re: Fluid Damage?
Ok, thanks for specifying.
As a mechanic myself, (Marine/small engines), I still find it unlikely unless you held the steam where it could penetrate for several seconds. JMO
Super Member
Re: Fluid Damage?
Yeah, sounding like an unfortunate coincidence it happened after you touched it.
IMO, For an interior detail only - unless you shorted the switch, which overworked the motor, I’m just not buying it. Especially since the cars I’m used to have overheat protection for the door lock motors where it stops letting them cycle if you hit the locks too many times.
You could also try calling the Mercedes dealers parts departments nearby and see how many of those door latches they stock. If it’s more than a couple, there’s your answer...
Is he a tunnel wash club member? Those cars I do see with water intrusion issues from frequent high pressure washes.
The hard part of the situation is no matter the reality, to him it happened after you touched it, so it must be your fault.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
Super Member
Re: Fluid Damage?
As somebody in the other side of that business for many years, highly unlikely. I wouldn't even think about paying for it unless I was shown the damage during the repair process. He already tried to get over on your once with the vent, no doubt in my mind he's trying to get over on you again.
Super Member
Re: Fluid Damage?
It’s a 7 year old car. Parts fail. Did he open the door when he picked the car up? I would let this one go to small claims court. Especially after he tried to make you pay for a vent he clearly broke.
Similar Threads
By KoshiL in forum Show N' Shine
Last Post: 05-19-2019, 12:11 PM
By catfish07 in forum Auto Detailing 101
Last Post: 05-03-2012, 06:44 AM
By PAR Detailing in forum Auto Detailing 101
Last Post: 12-13-2010, 01:19 AM
By Reddwarf in forum Auto Detailing 101
Last Post: 01-21-2009, 07:20 PM
By muddy in forum Auto Detailing 101
Last Post: 05-25-2008, 08:37 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
28 | 29 | 30 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 |
Bookmarks
