Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Junior Member
    Join Date
    Mar 2014
    Posts
    73
    Post Thanks / Like
    Best all around polish swirl remover
    I am looking to find the best all around polish/ swirl remover. I want it to be something that can be used as a one step product. I know there are products these days that have diminishing abrasives. So that they don't require another polish to be applied to remove anything they might have put into the finish.
  2. #2
    Super Member
    Join Date
    Oct 2013
    Posts
    286
    Post Thanks / Like
    Re: Best all around polish swirl remover
    It all depends on the condition of your paint.
    Do you have severe paint conditions or none or somewhere in between? You'd use different products for each instance.
    Give more info so members can help you.
  3. #3
    Super Member AeroCleanse's Avatar
    Join Date
    Nov 2008
    Location
    Neenah, WI
    Posts
    2,422
    Post Thanks / Like
    Quote Originally Posted by rmcnamara View Post
    Sonax Perfect Finish.
  4. #4
    Junior Member
    Join Date
    Mar 2014
    Posts
    73
    Post Thanks / Like
    My paint condition is pretty good. I have light swirls in the finish. On the other hand the finish on my wife's pilot is pretty severe. Other than wet sanding I will not be able to get those defects out.
  5. #5
    Super Member
    Join Date
    Oct 2013
    Posts
    286
    Post Thanks / Like
    For light swirls you could perhaps get by with a paint cleanser, anything more severe Sonax PF as mentioned above would be an example of an all rounder to a cut of 4 outa 6. Stuff harsher than that you'd need a compound first.
    Also be careful with wet sanding, you ought to know what you're doing.
    You sure you need wetsanding and not compounding?
    Post a couple of pictures if you aint sure.
  6. #6
    Super Member brondondolon's Avatar
    Join Date
    Nov 2013
    Posts
    1,254
    Post Thanks / Like
    Megs D151
    Sent from my HTC6435LVW using AG Online
  7. #7
    Super Member
    Join Date
    Oct 2013
    Posts
    286
    Post Thanks / Like
    Also forgot to ask what LSP you are planing to put on at the end?
    A wax, a sealant, or a coating? Each requires a different product beforehand. So a cleanser for wax could be different than one for a sealant or for a coating.
    (Just edited this so this is a reply to two posts down)
    And you are doing this by machine?
    Perfect finish is for machine use to the best of my knowledge.
  8. #8
    Super Member custmsprty's Avatar
    Join Date
    Apr 2012
    Posts
    7,494
    Post Thanks / Like
    Blackfire Total Polish & Seal
    2013 Genesis Coupe 3.8 Track Edition
    2015 Hyundai Sonata Limited, 2016 Pearl White Nissan Altima SR
    2019 Nissan Rogue SL
  9. #9
    Junior Member
    Join Date
    Mar 2014
    Posts
    73
    Post Thanks / Like
    I was just guessing with wet sanding. There are some pretty nasty scratches. The perfect finish sounds like somewhere to start. I will try to get some pictures tomorrow.
  10. #10
    Super Member FUNX650's Avatar
    Join Date
    Dec 2010
    Location
    Ohio, USA
    Posts
    21,057
    Post Thanks / Like
    "Diminishing" abrasives (DAT) have been around
    for a long while.
    "SMAT" abrasives are the fairly new kids on the block.
    (DAT and SMAT are Meguiar's designations)
    -Diminishing Abrasives (DAT) are a category of abrasives that actually break down.
    -Super Micro Abrasives (SMAT) are microscopic in size and do not break down (like DAT)
    IMO:
    Meguiars's #9 and #205...
    are most excellent all-around swirl-removers!
    "Be wary of the man who urges an action in which he himself incurs no risk."
    ~Joaquin de Setanti
Similar Threads
  1. Swirl Remover/Polish suggestions
    By jgh33 in forum Auto Detailing 101
    Last Post: 04-26-2017, 12:54 AM
  2. Polish or swirl remover?
    By carlg in forum Auto Detailing 101
    Last Post: 07-03-2012, 09:59 AM
  3. finishing polish or swirl remover?
    By flyinion in forum Auto Detailing 101
    Last Post: 05-19-2011, 04:50 PM
  4. Pinnacle Swirl Remover&Polish
    By 94LT1 in forum Pinnacle Wax
    Last Post: 04-27-2008, 01:22 PM
  5. New Swirl Remover/Polish
    By former86camaro in forum Auto Detailing 101
    Last Post: 03-29-2006, 07:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» June 2024
S M T W T F S
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
