Tornado Red Golf 7R - Detailed by Lawrence
An existing customer of mine recently purchased this car and with roughly 30k km's on the clock, it was obvious the previous owner didn't show it any love. The swirls you will see ran so deep into the paint, 2 compounding session wasn't enough to remove all of it, and in hindsight, a full wetsand would have probably been a better approach - but that wasn't the scope of the detail.
Whichever 'body shop' did the repaint on the front end also didn't show much love for their work either, but that's unfortunately par for the course in a lot of cases...
So time to get started. The engine bay was tackled first. It wasn't all that dirty and so the a basic clean was performed - everywhere was cleaned using Carchem APC and MF towels, Q-tips, a blower and various brushes. The plastics were then dressed using Autofinesse Dressel and the painted surfaces cleaned/polished/protected using Autofinesse Tripple
Next up the wheels. I was asked by one of the forum members to show the brushes I use for wheel cleaning so here is a small sequence of pictures to show what I typically do when cleaning the wheels.
First, I have a dedicated wheel bucket with a grit guard in it
I usually fill it halfway with hot water, then to 3/4 with cold, and some shampoo, and hit it with the hosepipe to create some suds
I then take my brushes
And place them in the bucket a short while before getting started on the wheels/arches/tires etc.
This is what the wheels looked like on arrival
Fender wells - HP rinse | Clean with Carchem APC | HP rinse | Dry | Dress with Autofinesse Dressel
Tires- HP rinse | Clean with Angelwax Billberry | HP rinse | Dry | Dress with Gyeon Tire Coat
Wheels - HP rinse | Clean with Angelwax Billberry | HP rinse | Dry | Seal with Gyeon Wetcoat
Brake Calipers - HP rinse | Clean with Angelwax Billberry | HP rinse | Dry | Seal with Gyeon Wetcoat
(no dedicated pics of the wheels after)
Then it was time to wash the car and decontaminate the car
Condition before
It was still early in the morning making it difficult to capture the defects in the paint
Pre-wash - HP rinse | Valet Pro Citrus Prewash | HP rinse | Angelwax Fastfoam | HP rinse
Wash - Carchem Luxury Shampoo | Lambswool wash mitts
Dry - Waffle Weave Drying Towel | ONR as a lubricant
Tar removal - Valet Pro Citrus Tar Remover
Iron removal - Carchem Revolt | HP rinse
Clay - Shield Heavy Duty | ONR as a lubricant
Inside Fuel Flap / Door Shuts - HP rinse | Carchem APC | HP rinse | Dry | Polish and Protect with Autofinesse Tripple
This was all over the passenger side rear quarter panel
Tar remover was used to knock off the bulk off it (the rest was polished off)
Then it was time to tackle the door jambs and boot jamb, and other little areas all too often overlooked.
Cleaned/Polished/Protected - Autofinesse Tripple | Q-tips | MF towels
The sunroof also needed some attention
Exhaust tip cleaning - Carchem APC
Exhaust tip Polishing and Protection - Menzerna Polishing Cream | Meguiars NXT All Metal Polish
Then it was time to tackle the paint.
Paint readings
Bonnet - 189µ to 264µ
Driver's side A-pillar 74µ to 93µ
Remainder of the car - 102µ to 138µ
Paint Correction - Menzerna FG400 | Blue Lake Country Hybrid Wool Pads / Flex 3401 (twice everywhere, with certain spots hit for a third time)
Paint refinement - Menzerna SF4000 | White Lake Country Hybrid Pads | Flex 3401
Paint Inspection / Pre-sealant Clean - Gyeon Prep
Protection - Dodo Juice Iron Gloss Sealant | Dodo Juice Orange Crush
Then the interior was sorted out
Glass - Autoglym Fast Glass
Plastics - Clean with Carchem APC | Wipe with damp MF towel | Protect with 303 Aerospace
Carpets - Vacuum | Brush | Vacuum
Leather - Clean with Carchem APC | Wipe with damp MF towel | Protect with Collinite 855
Door rubbers - Clean with Shield Heavy Duty Vinyl and Rubber Cleaner | Protect with Aerospace 303
Finally the exterior rubbers and glass were tackled.
Exterior Rubbers - Shield Heavy Duty Vinyl and Rubber Cleaner | Aerospace 303
Exterior Glass - Gyeon Prep
Re: Tornado Red Golf 7R - Detailed by Lawrence
I love your show n' shine posts. I noticed you taped off a body line when compounding/polishing the doors. Is it necessary to do this? I know it's a case by case, but I've always wondered when and which body lines should taped off.
Great post!!! Excellent work! Thanks for posting!
Scott Harle
Autodermatology
#autodermatology
Excellent work as usual Lawrence!
Beautiful job! Great detailed write-up as well. Thanks for sharing.
Yeah we all shine on, like the moon, and the stars, and the sun - John Lennon
Wowzers. Outstanding work as always Lawrence. Love your attention to detail.
You mentioned you had to perform two compounding steps from the severity of defects. You may want to grab some SC300... Don't worry, the 3401 equipped with the white Hybrid/SF4000 has the ability to pull out the more aggressive cutting step.
Thanks for sharing.
Thank you very much. I guess its a case of each to his own when it comes to taping, but I always tend to err on the side of caution - a roll of tape and an hour to tape up over the detail is far less of an issue to me, than potentially striking through an edge and having to absorb the cost of a repaint, and a knock to my credibility.
I typically assess each panel before correcting it and if I feel there is any possibility that I cannot properly correct the panel without the polisher running over an edge, I tape it up. This is only for the compounding step - for final polishing I don't usually tape up
Thanks Scott
Thanks Frank
Thank you
Thanks for sharing.
Thanks Mike. Oh how I wish for some SHC300.... As I have mentioned before, the availability of detailing products over here is limited primarily to 2 companies that bring stuff in.... and only 1 has been bringing in the Menz products, and even then it has been pretty much only FG400/PF2300/SF4000, 3-in-1 and Powerlock... It looks like they are however phasing that out and focusing on Angelwax products, and so I am going to have to start bringing it in myself if I want it.
The problem though is a) the current exchange rate is beyond a joke for us and b) as everyone knows, shipping costs are quite crazy (especially bringing in some weight) and are only exacerbated by the exchange rate...
I am in the process of trying to find some local guys who would be willing to do a group buy and split shipping costs, but its proving a bit tougher than I'd hoped.
Glad to know though that SF4000/white has enough pull to deal with the hazing from the initial cut with SHC300
Beautiful as always my friend!
Great Job!
What did you think about the car? I'm thinking of getting one of these as my Daily Driver.
Thanks for sharing.
By lawrenceSA in forum Show N' Shine
Last Post: 09-06-2015, 03:26 PM
Last Post: 07-29-2015, 01:50 PM
Last Post: 07-05-2015, 01:50 AM
Last Post: 09-15-2014, 08:08 AM
Last Post: 07-30-2013, 01:09 AM
26 | 27 | 28 | 29 | 30 | 31 |
