Results 1 to 10 of 10
    Aug 2015
    94
    First Detail - 2015 GMC Sierra Denali
    In truth, it isn't done yet. I work a lot and I'm slow. Still have to do engine bay, and interior - as well as the black trim and tires.
    But the polish/correction and wax of the exterior is complete. I think she looks pretty daggum decent for my first go round with the PC.
    Untitled by acevedor2, on Flickr
    Thought this last one was a blemish or something in the paint because of the "streak" that almost looks like a NIKE swoosh. It apparently was just a shadow or reflection from the fender curve above it because there is nothing there!
    Apr 2012
    7,494
    Re: First Detail - 2015 GMC Sierra Denali
    2019 Nissan Rogue SL
    Aug 2011
    543
    That is one super nice truck. Congrats. Nice job
    Super Member parttimer's Avatar
    Aug 2013
    1,564
    I did one of these two weeks ago, since back surgery I go a little slower, took me from Friday night to Sunday morning for exterior with a coating and the interior! Just HUGE trucks!
    Aug 2010
    New Jersey
    15,173
    Wow, came out great!
    Super Member richy's Avatar
    Mar 2007
    Windsor, Ontario
    5,158
    Whatever you did, it looks good.
    Aug 2015
    94
    Thank guys. I appreciate the compliments. Parttimer is right - these things are huge and it took me about three days just to do the outside. I think my biggest problem was not having an aggressive enough pad/compound so it took multiple passes. I used HD Polish and HD Speed, followed by HD Poxy. I should have gotten HD Cut. I initially was afraid to use any pad more aggressive than the LC Orange. I eventually went with the HC Yellow and that helped a bit. Next up is the interior - after I finish installing the AMP Powersteps....
    Newbie Member chaves_auto's Avatar
    Mar 2014
    Solid work and beautiful truck!
    Super Member lawrenceSA's Avatar
    Feb 2012
    Durban - South Africa
    1,713
    Really nice work for your first time
    You should be proud!
    If I may offer a little advice....Having used a similar machine to correct about the first 70'ish cars detailed I know it is certainly capable of 'getting the job done', but it is comparatively 'underpowered' and so squeezing the most out of it will make life a bit easier for you.
    I haven't used any of the HD range, so I can't talk to which product you should be using, but with any compound/polish, a few things will help increase the amount of clear you are removing in each section you work.
    Shrinking the size of your working area - I found working section of (a square) 3 pads x 3 pads in size offered good results.
    Slowing down your arm speed - which allows the abrasives time to abrade away the paint
    Decreasing the diameter of the pad you are using - the polishing force is concentrated on a smaller surface area, plus less frictional drag from the pad
    Decreasing the thickness of the pad - the machine is better able to transfer its power from the backing plate to the working face of the pad.
    Increasing the downward pressure you apply to the machine - but not too much that you lose pad rotation
    Increasing the machine speed - but with some polishes this will increase dusting and/or decrease working time.
    As nice as that truck looks, I am glad we don't get them over here in South Africa... that's a lot of real estate
    Good luck finishing it off
    Oh and post some more pics when you are done
  10. #10
    Feb 2011
    Minot, ND
    12,365
    Nice work on a beautiful truck!
  1. 2015 Acadia Denali
    By Farmallluvr in forum Show N' Shine
    Last Post: 08-22-2018, 07:12 PM
  2. Replies: 6
    Last Post: 12-21-2015, 02:40 AM
  3. Replies: 10
    Last Post: 10-29-2015, 04:16 PM
  4. Black 2014 GMC Sierra Denali, coated
    By parttimer in forum Show N' Shine
    Last Post: 09-28-2015, 12:59 PM
  5. Replies: 19
    Last Post: 08-26-2010, 05:54 PM
