Sublime Green Challenger Hellcat Cquartz Finest New Car Protection - Tampa, FL
The owner of this Sublime Green Hellcat opted for our Ultimate Cquartz Finest New Car Prep service which includes a full paint correction, XPEL Ultimate Clear Film on the front nose cone and Cquartz Finest to keep everything protected and easy to maintain. We also removed the wheels to apply Cquartz Finest to the wheel faces and inside barrels, as well as the brake calipers.
This Hellcat was in good company!
Pre-Inspection
The car had some minor defects and swirls that needed to be corrected.
There was also a "film" over the entire vehicle, I could only come up with it possibly being a layer of adhesive from the plastic that is used to protect the vehicle during transit from the factory. It shows up as tiny specs or dots in the paint surface, which made the paint look a dull. Luckily, it was removed in the polishing step and made for a dramatic change in gloss.
Multi-Step Paint Correction
There were a few spots on the car where something was rubbing on the finish creating dull spots and scratches.
Now safely removed after paint correction.
Some even worse were found across the roof near the windshield.
Also, safely removed after paint correction.
Below are a few photos that show the defects in the paint removed after the first stage of correction. The paint will still be refined even further with additional steps of polishing for the most clarity in the clearcoat possible.
Wheels Off Cquartz Finest Application
This is a very popular option, especially with our sports car enthusiasts. Each wheel is carefully removed from the vehicle, cleaned inside and out, then protected with two coats of Cquartz Finest. This makes general maintenance of the wheels a much easier task, as the brake dust can be easily washed away instead of embedding into the wheel finish.
As you can see the Hellcat is pretty notorious for heavy brake dust coming from it large Brembo brake system.
Cleaned, prepped and protected with Cquartz Finest.
Cquartz Finest works amazingly well on matte surfaces. It maintains the matte finish, while giving it a very rich look and great durability, even in a harsh environment such as the wheels.
The calipers receive the same treatment as the wheels to protect the powder coat finish. The inner liners and wheel arches are also cleaned and dressed. Before.
After.
Xpel Ultimate Paint Protection Film
Xpel Ultimate Paint Protection Film was applied to the nose cone to protect against road debris and rock chips. Sorry, again on a time crunch and short on hands, so I wasnt able to take photos during the install. Yes, the car does have clear film in all the following photos!
Cquartz Finest Ceramic Paint Protection
Re: Sublime Green Challenger Hellcat Cquartz Finest New Car Protection - Tampa, FL
Nice work! Looks very nice!!!
Scott Harle
Autodermatology
#autodermatology
Great work on an awesome car!
Beautiful. That color is different, but grows on you.
Xpel seems to have darkened the colour a bit... the diference between begore and after polishing is amazing good job..
Sent from my SM-N900W8 using Tapatalk
David
Owner, Operator Max Detail.
Wow that is one sweet ride, thanks for sharing!
Very nice. The more I read up on Xpel, the more I want to do it.
I think most of the color difference are seeing is more from the color difference between the plastic bumper and metal fender. Thank you for the compliment!
Thanks! If you want the best protection for the front of your car, paint protection film is definitely the way to go. We use mostly XPEL and some Suntek as well.
By Presidential_Detail in forum Show N' Shine
Last Post: 01-28-2016, 11:26 AM
Last Post: 11-13-2015, 09:21 PM
By RaskyR1 in forum Show N' Shine
Last Post: 09-29-2015, 04:17 PM
Last Post: 06-08-2015, 02:15 PM
Last Post: 05-25-2015, 07:14 PM
26 | 27 | 28 | 29 | 30 | 31 |
