Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Super Member gofast908z's Avatar
    Feb 2009
    Bay Area, CA
    746
    1973 Porsche 911 Targa restorative correction detail - 62 hours
    Just completed this car last week at the shop. Normally I like to post cars in the order that they were done and I have a lot to catch up on, however this car was pretty special and I wanted to post it up sooner rather than later.
    Long time client recently picked up this all-original 1973 Porsche 911 Targa with the purpose of enjoying it, but he also wanted to enhance the appearance as much as possible while maintaining the originality. This little gem of a Porsche was victim to some bad polishing in its past. Nearly every panel edge had burn marks. The hood and engine cover were particularly abused. In addition to that, the paint was quite thin presenting a challenging task, to restore the condition of the paint as much as possible without further damaging the compromised areas. Much more info provided throughout this writeup.
    Total time was 62 hours, not including picking up and delivering the car from the owner's home in Palo Alto and back again.
    Condition when I got it to the shop
    First up was addressing the numerous dents and dings. There were quite a few. The hood was a challenge with a large arm-print dent right in the center. It was a severe dent and made worse by the rough texture on the underside of the hood making leveling it out quite challenging. So I had a master dent removal tech come out to fix it.
    Right at the front of the hood there were a couple bad dings like this one. The back side of this part of the hood is sealed and double-walled. Not an easy fix.
    The arm-imprint dent
    The ripple effect of the arm dent caused ripples all the way up the center of the hood
    Just a few of the many dings on the driver's door (counted over a dozen)
    Someone inexperienced attempted at fixing the dings on the engine cover. Several of the dings had been pushed out making a proper repair difficult. Luckily the attempt by the previous dent removal guy did not crack the paint.
    Plenty of crud, dirt, old wax, and scratches all round every single letter on the engine cover
    Plenty of dirt and dead paint under this beautiful piece. Would be removed to gain access and restore this area. Its the small things that make a big difference at the end
    While I worked on the emblem and grate removal, the master tech Joe from Dent Pro worked his magic for many hours to remove several dozen dings and dents.
    The condition of the engine cover after emblem removal and dent repair. The long road to restoring this was just beginning.
    As stated in the beginning, many areas had been burned by previous detailers. These particular edges had been burned quite badly....note the white color along the edges.
    The original single stage paint had plenty of swirls to go around
    Feb 2009
    Bay Area, CA
    746
    Re: 1973 Porsche 911 Targa restorative correction detail - 62 hours
    50/50 shot after compounding
    Plenty more defects on the driver's side
    Notice again, extensive burns along edges....
    Chips and burns here
    The wheels were in a poor state. Looked as though someone had use wheel acid on the bare anodized aluminum and heavily stained it. The owner requested that I fully polish the wheels out.
    The inside barrels were quite bad too. Lots of old wheel weight adhesive left, tons of brake dust, and a thick layer of grease under all the brake dust.
    After stripping off all the grime. Some staining would not come off, but not bad considering the age of the original finish.
    All taped up to protect the flat black paint from the polishing
    Making progress
    Much better....HD Metal made for some good results
    Looking better
    Feb 2009
    Bay Area, CA
    746
    Exhaust tip before/after
    Fog light housings polished
    With all the correction done and coated with CQuartz UK, it was time to start putting things back together
    Paint in the engine bay needed some polishing. It measured around 40 microns, so only light hand polishing would be carried out, nothing aggressive.
    These slats were filled with ancient compound and wax residue. So after removing this, every individual slat was hand polished.
    After all the old gunk was removed, you could see that each individual slat was numbered!
    Sehr Deutsch.
    The paint underneath now matched the rest of the paint
    Polished up this trim as well
    All finished and looking glossy now
    Wheels looking sharp. Also owner sourced out new polished and painted center caps to match the wheels
    Payoff for doing the emblem removal
    Feb 2009
    Bay Area, CA
    746
    Final shots in the sun
    Delivered back to the owner...with the paint reflecting everything around it. Look close and see the smile on his face.
    Thank you for looking!
    Fertig.
    Super Member Aaryn NZ's Avatar
    May 2012
    New Zealand
    1,930
    Simply outstanding my man!
    Thoroughly enjoyed reading such an in depth post of your work resurrecting a gorgeous Porsche.
    I have a soft spot for early Porsches so maybe a bit biased but theres no denying the craftsmanship of a fantastically carried out detail.
    Top work mate - Bravo!
    Aaryn NZ.
    Regular Member SSStang's Avatar
    Apr 2013
    Troy Tx
    101
    Just amazing what a transformation.
    Super Member haris300's Avatar
    Mar 2014
    Sugar Land, TX
    999
    That was unbelievable. I really like how you went about masking the paint on the wheels . Also like those old California plates. Great attention to detail. Well done.
    Super Member Gary Sword's Avatar
    Nov 2006
    Southwest Florida
    4,168
    Lots of work with great results.
    Super Member blown03's Avatar
    Mar 2013
    217
    Wow man , that looks like allot more then 62hours of work . Awesome ,awesome job with amazing attention to detail . I bet he's still wearing that grin !
    Daren
  10. #10
    Mar 2014
    308
    Salute, my friend...
    Fantastic work!!!
    Quote:
    Originally Posted by mcate
    Black isn't a color, it's a part time job.
  1. 1993 Porsche Targa
    By Sizzle Chest in forum Show N' Shine
    Last Post: 07-11-2019, 10:17 PM
  2. 2007 Porsche 911 Targa 4
    By DetailDrivenEugene in forum Show N' Shine
    Last Post: 07-01-2019, 09:42 AM
  3. Porsche 991 Targa pics!!!
    By Sizzle Chest in forum Off-Topic
    Last Post: 03-11-2014, 01:18 AM
  4. Replies: 11
    Last Post: 01-21-2013, 02:47 AM
  5. Replies: 9
    Last Post: 12-11-2011, 06:50 PM
