Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    Super Member RaskyR1's Avatar
    Apr 2008
    Shakopee, MN
    3,733
    E30 M3, Multi-Step Correction and Partial Wet Sanding
    The owner of this fine example of German Engineering recently purchased the car and wanted me to do what I could to get the paint looking its best within his budget. Upon inspection it was evident that it had been repainted some time ago and that there was some excessive shrink on the top panels and a few other paint issues that needed to be addressed.
    Car as it arrived (nice and clean)
    Shrink on the hood can be seen from the lack of gloss and distorted reflection
    Washer nozzles removed for sanding and polishing
    Close up of shrink
    Sanded with 1500/3000 grit Meguiar’s sanding discs (hand and DA)
    After compounding with the Rupes LHR21 and KBM205 method
    Close up of shrink on the spoiler
    At a distance
    Close up of spoiler after sanding and compounding
    At a distance…notice the difference between the spoiler and the trunk
    Spoiler removed
    A few areas on the car had these “goose bump” protruding from the paint. I’m not 100% certain what causes this but I’ve seen it before on repaints. Its likely solvents or moisture trapped under the paint, possibly in the primer or base coat, which are trying to escape. I don’t suggesting trying to sand these defects out, for obvious reasons, but it looked bad and I decided to test out sanding in a discrete area, which turned out great. It’s not 100%, but a huge improvement. I lightly sanded them here so they were easier to see. The touched up chip can be used as a reference point.
    After
    Swirls and RIDS throughout
    50/50 shot
    I spent about 10-12hrs carefully wet sanding and compounding….
    An example of when the rotary is the better tool for the job.
    Great example of where the Rupes TA50 and 2” pads shine
    Finished shot prior to LSP….two different aperture settings
    I like this one
    After pics….I had hoped for sun, but I’m grateful that the owner made it home without getting rained on.
    As always, thank you for viewing my work.
    Rasky
    Quote Originally Posted by CieraSL View Post
    http://Raskysautodetailing.com/
    May 2012
    NYC
    50
    Re: E30 M3, Multi-Step Correction and Partial Wet Sanding
    E30 M3. One of my all time favorites. Great job on the clean up!
    Super Member CarolinasFinestDetailing's Avatar
    May 2011
    Charlotte, NC
    1,556
    Amazing piece of German engineering and you made her look proper. I just hope he doesn`t "stance" it now.
    Super Member JSou's Avatar
    Dec 2012
    Northern Virginia
    1,635
    Too nice.
    Junior Member Ecoshine's Avatar
    Apr 2014
    Toledo, Ohio
    61
    Great job, I've been considering the rupes 2". Thanks for sharing
    Aug 2012
    Laguna Hills
    430
    Great job on a beautiful car. They are a true classic.
    "The shortest and surest way to live with honor in the world is to be in reality what we would appear to be." --- Socrates
    Super Member oldmodman's Avatar
    Sep 2007
    2,563
    Fantastic result.
    I am particularly impressed with the spot sanding you did on those repaint defects. Most people would have just let that sleeping dog lie.
    Mar 2013
    Coral Springs, FL
    285
    Wish I could own one of those! Great work! What did you use for the LSP?
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Great work
    2" pads from B.D.?
  10. #10
    Aug 2013
    St Louis metro (Illinois)
    5,847
    Beautiful! The E-30 M3 is an upcoming classic.
  1. Replies: 35
    Last Post: 05-28-2017, 09:57 AM
  2. Replies: 18
    Last Post: 08-12-2016, 08:17 PM
  3. Heavily modded Corvette Z06 multi-step correction
    By gofast908z in forum Show N' Shine
    Last Post: 12-07-2015, 10:02 PM
  4. Replies: 16
    Last Post: 11-03-2015, 11:47 PM
  5. Replies: 15
    Last Post: 05-15-2014, 11:06 AM
