There are things on a car that particularly when damaged gives the whole vehicle a bad look, and yellowish headlights are one of those.
I saw 3M kit on shelf many times, I'd give it a try next time I see it for an affordable price.
Thanks for sharing,
Kind Regards.
Thank u not bad for 30 bucks. i only had to do 1 headlight because the other one was new.
probably can do about 6 lights with the kit. only had to use one 500 grit and one 800 grit before going to the 3000 pad, when done it looked just as good as the other headlight
I've used that kit on two of my cars and had great results as well. My only critique is I wish it came with more of the 500 grit sanding discs. I just did my Mercedes which has headlights with a lot of surface area and I ended up needing more sandpaper for the first sanding step. I bought 6" adhesive backed sanding discs, traced the small discs included with the kit onto them, and cut out more small discs.
Alex - Portland, Oregon
'03 Mercedes C230 Kompressor (Black Opal / Gray) / '91 Jeep Cherokee Laredo (Colorado Red / Gray) / '90 Ford Mustang GT (Oxford White / Gray)
