2013 BMW 335i M-Sport Correction and Opti-Coat - Anthony's Auto Detailing in NJ
This vehicle was fairly straight-forward. Typical defects. The car is taken care of very well by the owner, but anyone in the Northeast knows how brutal this past winter was. After assessing, we decided to go with a two-step correction and finish off with Opti-Coat for permanent protection. This is the first time the owner ever had a car coated, and was a little hesitant, but I think he will be very happy with it over time.
I used me Rupes LHR15E for almost the whole vehicle, using Kevin Brown's method with M205 for my initial cutting on a meguiar's MF disc, followed by OPT Hyper Polish on a tangerine hydrotech to amp up the gloss, as well as prepare the surface to be coated. I followed up with an eraser wipedown to ensure any excess oils were removed, then I coated. The wheels were coated as well.
To start off, here's a little demo of Iron-X I used on the wheels.
https://www.youtube.com/watch?v=yeYGzWQ7_r0
Anyway, here is how the car sat as I arrived.
The damage didn't look TOO bad due to the flake in the paint, but the paint lacked depth and clarity due to this.
And the dreaded BMW brakedust
The Brinkmann Xenon light showed the cars true condition after the wash and decon
Much better
A little 50/50 action
You can see all the clarity that was brought back to the paint
Typical B-Pillar damage
Not PERFECT, but I refuse to chase too deep on these, they are soft and dangerous.
All finished
The owner was thrilled with the turn-around. Some deeper issues remained, but it wasn't in the budget, nor was it worth wetsanding these small issues.
Thanks for looking!
Anthony Onorato
Clementon, NJ 08021
ANTHONYS AUTO DETAILING, South Jerseys Premier Auto Detailing Serivce
anthony@anthonysautodetailing.com
Re: 2013 BMW 335i M-Sport Correction and Opti-Coat - Anthony's Auto Detailing in NJ
Man, you 'killed it', 'smashed it', please, find an english term for 'Wow you did a very good job!, the best possible to turn this one around'.
It's clear from your first pictures how dull the paint was at first, I also liked your comment on pillars, yes, they are thin and soft generally...
Nice write up, well, like I've tried to say, you busted it! hahaha
If possible, can you briefly talk a bit about M205 on cutting MF disc, I have both, enjoy MF discs a lot, and just received my 4 3/8 plate for the Flex so I can keep using my MF (5.5") from old DA... I have dozens of it (both cutting and polishing discs).
As I don't have enough time for the thorough testing needed, any advice you can give on M205 and MF disc would be awesome, and that can be expanded in priming the pad, polisher speed, arm speed, passes, pressure, cautions, etc,
That way I can start someday doing a test spot with this setup when I find properly, but your tips may turn things easier for me if I had a START point.
Thanks for sharing this beautiful work with us,
Kind Regards.
― Isaac Newton
Beautiful work on that Schwartz BMW Anthony! Looks amazing now!
simply amazing
Awesome job sir! What a difference. That is mobile detailing done right.
And, is that your GT in the background?
Best photo of Iron-X in action ever:
Beautiful work on the car too
Stellar work Anthony! That's my car with 2 extra doors and my paint is Black Sapphire Metallic which, if dirty or marred up with swirls, looks dark grey instead of black. THAT is how it should look.
Fantastic job Anthony! Looks beautiful
2013 Accord V6 coupe 6MT San Marino Red
Wow, GLOSSY!!! Did you use iron x as the wheel cleaner or did you clean the wheel first?
By statusdetailing in forum Show N' Shine
Last Post: 07-24-2014, 09:21 AM
By Anthony Onorato in forum Show N' Shine
Last Post: 02-09-2014, 12:16 AM
By Jsmooth in forum Show N' Shine
Last Post: 07-05-2013, 01:06 PM
Last Post: 06-12-2013, 12:56 PM
By SpeedFreak81 in forum Show N' Shine
Last Post: 05-24-2013, 07:23 PM
