2010 Mustang GT, UA BLACK :) {and im a newbie}
This is my first "real work" project. I've done some work on my old daily drivers, and the family Durango, mostly water spot removal. I was stationed in Hawaii (Oahu) for 17 years and the water there is terrible. I've been a member here for a several years, as a sneaker... reading and learning. I have a PC 7424 and numerous Lake Country pad and currently i'm using XMT swirl remover products, 4-1 and XMT carnuba glaze and Detailers Pride sealant. i'm finishing with mothers synthetic wax.
so, why am I here.
i'll post my pics and hope you guys can help.
I don't know what the "marring" is on the photo after wash and clay. look to the left of the photo. what is that? why is it there? i'm using mothers clay and speed lube for the clay. am I doing something wrong?
the rest of the pics are pretty self explanatory. I for the life of me don't understand how i'm getting the small circular swirls afterwards. I know arm speed, pressure and pads play a part.
so, arm speed is "slow-ish". pressure is enough to "push the pad down" a bit.
Pads:
xmt 3 I use Orange Low Profile Light Cutting 5.5 inch Foam Pad.
xmt 1 I use Pink Low Profile Cutting/Polishing 5.5 inch Foam Pad
for the glaze and sealant I use
Gray Low Profile Finishing 5.5 inch Foam Pad
and for the wax I use
Red Low Profile Ultrasoft Wax/Sealant 5.5 inch Foam Pad
any and all help is greatly appreciated. if I missed an article please point me that way.
if you are willing to share any of your own tips, "I'm all ears".
thank you very much in advance.
Regards,
tunakiller (Rob Gibbs)
Re: 2010 Mustang GT, UA BLACK :) {and im a newbie}
Welcome to autogeek, and nice work on that muscle car keep up the good work
You need to use a cutting pad (orange/yellow/cyan/MF) or you need to adjust your technique. My guess is a little of both. With the PC you may need a lot of downward force and a very slow arm speed - that is why most of us are recommending Rupes or Griots machines.
But - it can be done with a PC.
i'm using an orange cutting pad, (Lake Country).
thanks for the advice.
so the small swirls that are coming up after I use xmt 3 and 1 are from the machine and my mistakes? not using enough downward pressure and I need to slow down?
what are the marring marks after I clay?
again, thanks!
rob
Marring can sometimes just happen from claying. On dark cars it can be unavoidable. Clay has abrasive properties to it.
I'm wondering if you are removing the swirls to begin with? Usually with new users the issue is technique not being aggressive enough. I missed you had used a cutting pad.
I would try it again, prime your pad, use a lot of downward force (PC still spinning), and make your arm speed 1-2" inches a second. You want to do about 6 passes.
Really focus on moving the machine slow and think about what you are trying to achieve (cutting paint with a foam pad).
ok, thank you. now I know just how much to slow down my arm speed and the clay process may just simply be unavoidable.
as far as the swirls, i'm definitely removing them. i'll have to get better at my picture taking skills, but if you look at the pictures, you can see sever swirls before I start, and small, circular ones when im finished.
thank you so much for the replies. it really helps!
regards,
rob
This right here:
Looks like marring from XMT 3. So, you may need to go more aggressive with your finishing technique - XMT 1 - (slow arm speed / more passes / more pressure).
XMT 1 should be cleaning that up.
thank you so much! now I know which direction to pursue!!!
regards,
Rob
should I be using an orange pad or a white or pink for the no 1?
By Mike Hoekstra in forum Show N' Shine
Last Post: 09-13-2020, 08:18 AM
By RaskyR1 in forum Show N' Shine
Last Post: 05-03-2016, 11:32 AM
By dbusch68 in forum Ask your detailing questions!
Last Post: 12-26-2013, 11:47 PM
By 05xrunner in forum Show N' Shine
Last Post: 10-18-2010, 02:53 PM
Last Post: 05-13-2010, 04:43 PM
