Well on tap this weekend was a beauty a 2013 Honda CRV. The paint was not in bad shape at all a few light swirls and just a few RIDS here an there.
Exterior:
- Wash with CG Wash and Clear Red
- Wheels cleaned with Megs wheels Brightener and then sprayed with with then new Iron-X
- Tires cleaned with Megs Non Acidic Wheel and tire cleaner with a foam sprayer
- Chemical Decontamination with Iron-X over the exterior surfaces
- Clayed using the Speedy Prep DA pad and the towel for the tighter areas
- All trim taped off
- Test spot done
- Rupes 21 with 5" BP with a BnS polishing pad and M205
- After polishing the entire vehicle was wiped down with CarPro Eraser
- Finally Opti-coat was applied to all exterior surfaces.
- Tires were dress with with Opti-Bond tire gel
Some before photos:
After photos:
Thanks for looking!
