Re: Premier Auto Detailing by Evan: Helping a Forum Member
Great improvement! Those looked like some pretty heavy defects.
I have never used HD Polish, so I am unaware of it's cutting/finishing abilities, nor have I used BnS pads, but from the after photos it is evident that there is still quite a bit of marring. Don't get me wrong - the car looks FANTASTIC, and to be honest, that micro-marring may not even be noticeable in the sunlight (sometimes the Brinkmann is less forgiving than the sun).
I was just curious - does the HD Polish need to be worked for an extended period of time to provide a more perfect finish? Or, perhaps a more aggressive polish and/or pad was needed to remove the haze from the heavy cutting? Just some thoughts.
Here is what I am referring to:
^Notice the trails of light coming from both the light and camera flash. You can also the very light defects left from the heavy cutting process.
Retired Professional Detailer
HD Polish has a very long work time and the finish you get can be set to near anything you need by your pad. If you are on a soft clear system you can use a blue or black pad and finish perfectly.. on hard clears I will often even use an orange foam pad to finish and always get great results.
Let me know if you have any other questions I have used polish from its release on an almost daily basis.
Sent from my DROID RAZR using AG Online
I was curious about that myself. Looks good though! Be sure you tell him his Honda symbol is missing off the front grill.
Shane
So you're stating that he would have achieved better results with a slightly more aggressive pad?
That is what I would have recommended as well, but I just have no experience with that product. From what I have read, HD polish finishes down excellently (so I have always thought of it somewhat like a medium polish with excellent finishing capabilities, somewhat like Sonax Perfect Finish)... I enjoy using SPF with an orange light cutting pad, and get fantastic results with that combo - even on some softer paints.
Hd polish is SMAT
sonax pf is dat
Cant really compare the 2 as far as cut and finishing down, 2 different beasts both great in their own way
Sent from my SCH-I605 using AG Online
Originally Posted by MajinAl
Hd polish is SMAT
sonax pf is dat
Good to know... I knew SPF was DAT, but as already stated... I know nothing much of the HD product lineup.
So that means working the HD polish longer would not have yielded a better results for Evan, and that simply using a more aggressive pad should have (theoretically) done the trick.
Zach the photo you at referring to was after compounds so some light hazing from the cutting pad. Should have noted that. The HD polished finished down great and left no hazing.
Nice improvement! For a 2 step tho I would have aimed for less marring, but it's still a good difference!
Edit: my bad lol just read the post! Nice to know that was after compounding and not after polishing!!
Well that clears things up! (no pun intended! haha)
By Evan.J in forum Show N' Shine
Last Post: 06-02-2014, 07:22 AM
Last Post: 06-01-2014, 04:28 PM
Last Post: 12-16-2013, 07:57 AM
Last Post: 10-24-2013, 11:52 AM
Last Post: 09-12-2013, 05:41 PM
