Re: IronX & Tuff Shine Tire Coating
What dilution rate were you using for the OPC?
For tires I use 3:1.
But i have to add that even that ratio was just a bit sub-par compaired with the Tuff Shine Tire cleaner.When I saw no more brown lifting from the tires with the OPC @ 3:1,I was still getting the brown to lift with the Tuff Shine Tire cleaner.
Team Flex PE14-2 150(Serial#0005)/3401/3403/XFE 7-15
Wow Chris! That is a helluva transformation!
Tuf Shine is my all time favorite, hands down. The Tuf Shine brush and cleaner are top notch as well.
Does Tuff Shine "sling-off" on to the doors and quarter panels? Looks like a gppd product.
Should be getting my order of tuff shine in tomorrow.
You should enter that "after" in the Great Looking Wheel Hall of Fame. Looks awesome. I love Tuff Shine on my daily driver. I think it's been around 3 weeks since I first applied it. Since then, there's been 2 washes (blaster it with pressure washer) and many rains. It still looks great. It may have faded a hair, but that's it. The best part is, once it's done it's done. Cleaning of the tires is as easy as cleaning of paint. No nasty silicone or brown stuff to get out of the tire. Then, all you need to do to re-apply is just refresh the coating on the tire. I was only getting a little more than a week with other tire products if there was a rain or two. Also, TS's coating "locks in" the factory UV chemicals in the tire (per an email from TS) and has its own UV protection. It is to tires what coatings ate to paint. You didn't really say, what are your thoughts on the coating?
No, not at all. It dries like a coating. Passes what TS calls the "White Glove Test". Coat tires, let dry, and rub with a white glove. Glove stays clean and there is no product transfer. Dries quickly, about ten minutes a coat. Once coating is on, pressure washing tire is pretty much all you need to do to clean it (unless very dirty, then you can use a mild soap like car wash).
To answer swaincyouth question,I think this is my goto tire coating/dressing from now on.It has become my favorite as well...hands down!
Thank you Jim.It's because of the sample you sent my way I had interest in the TuffShine
As swaincyouth had mentioned...NO SLING OFF
You'll love it!
Yeah,they really turned out great(wheels & tires).
By gregory1420 in forum Auto Detailing 101
Last Post: 11-26-2017, 10:15 PM
Last Post: 08-05-2017, 10:28 PM
By firecorgi in forum Show N' Shine
Last Post: 05-23-2014, 08:06 PM
By wujekcity in forum Auto Detailing 101
Last Post: 05-22-2014, 12:25 PM
By ShineTimeDetail in forum Show N' Shine
Last Post: 10-26-2012, 07:13 AM
