Re: 350z Engine Detail
As an owner of a 1991 300ZX TT I was interested in your process. Can you share with us what brushes you used. Also, how did you apply the Hyper Dressing - wipe it on, spray it on? Did you turn the engine on and let it kind of bake on? Thanks for your reply!
Sure thing, I guess I left a lot out on the original post. The brushes I used were just various sizes of detailing brushes much like what swissvaz and raceglaze offers. Because this is my actual car I did not cover any of the electronics and just made sure I did not soak anything with a bunch of water. The main area to watch out for on these vq mototrs is top of the valve covers where the coil packs sit along with the spark plug tubes where water could get into. I liberally sprayed my apc over the engine and let it sit and dwell for a few minutes. I went around with the brushes and tried to agiatate any dirty areas with them. I then pressure washed the dirt and apc off being careful of the above mentioned areas. I never started the engine during any of this. After wash, I used clean microfibers to dry and remove any remaining dirt. I dressed all of the black plastic and hoses by spraying them with the dressing and then going back over them with a towell. After this I went over the painted areas with opti cleen to remove any dressings that may have gotten in those areas. I hope this helps and feel free to ask anymore questions.
By flyinion in forum Show N' Shine
Last Post: 09-01-2011, 01:31 PM
By Oakes in forum Show N' Shine
Last Post: 04-01-2011, 04:28 AM
By gohandbz8 in forum Show N' Shine
Last Post: 07-27-2008, 06:17 PM
By scottgt in forum Show N' Shine
Last Post: 02-03-2008, 03:52 PM
Last Post: 06-17-2007, 11:04 AM
