01-21-2012, 07:52 AM
#141
Re: Headlight sealant: spar urethane vs. opti coat 2.0
Originally Posted by cyga
The Minwax (spar urethane) product that is used during restoration - is this Minwax 43200/63200 or something else?
I'm asking cause I have no other option than buying it online and I need the exact name of it as amazon tends to give different pictures for different products (I definitely don't want to buy semi-gloss, satin, etc).
I'm sorry but I have no idea if those numbers belong to the right or wrong type. I looked all over my current can and find no such numbers. Maybe someone else can help.....?
01-21-2012, 08:58 AM
#142
Those numbers look to be the UPC numbers, the ones under the bar code.
Maybe take a look at Minwax's web site...they may have those numbers showing.
Bill
01-21-2012, 12:37 PM
#143
The bar-code number on my can of Minwax Helmsman, Spar Urethane, clear gloss that I used is: 27426 63200.
Don't know what the difference in numbers would designate. These numbers are on the 32 fl oz (1 qt) can.
Smoke Metallic '06 Altima
01-21-2012, 01:17 PM
#144
I think the mystery is solved, I have the pint size Helmsman Spar Varnish (Clear Gloss) 27426 43200
Fred R. Elias Jr.
Warren, MI. 48091
1-586-755-1245
01-21-2012, 02:46 PM
#145
Ah, yes. Different number, different amount.
01-22-2012, 06:10 AM
#146
Perfect! Problem solved
Thanks guys
01-23-2012, 07:38 PM
#147
3 month update on Car #3 Pt Cruiser
The third car in this test was near the three month update, so I snapped a few pictures, and here is what I found.
Opti coat 2.0 side
Not sure why this picture looks a little hazy, but the lens is still clear in person.
Notice the slight "ghosting" on the interior, it was there before restoration and unrepairable with this process, both lens have it, but the drivers side was the worst.
Basically this lens has not changed in appearance in my opinion, the thing different about this car compared to test vehicle number one is that the pt cruiser is under a car port a majority of the time, and is washed regularly. Test vehicle number one is outside 24/7 and is rarely washed.
Spar urethane side
This lens shows no signs of deterioration either.
The spar urethane side does show more reflections in its finish than the opti coat side, giving the spar urethane a little advantage. I don't expect either lens to show much deterioration until we hit summer, but I will continue with 3 month updates on this vehicle.
Test vehicle number three(chevy malibu) is past 3 months, but I won't have access to this vehicle until next month, so I will update that vehicle when I see it.
01-23-2012, 08:55 PM
#148
"...Notice the slight "ghosting" on the interior, it was there before restoration and unrepairable with this process, both lens have it, but the drivers side was the worst..."
Your test vehicle is a Chrysler PT Cruiser; I've noticed this on a number of Chrysler-Dodge vehicles (including my own).
02-13-2012, 05:01 PM
#149
02-13-2012, 05:51 PM
#150
Looking good. Going to pick up a quart next time I'm at Lowes.
"Tell Me What I Can't Do, and I'll Show You What I Can Do." ~Eugene
By boostedsil40 in forum Auto Detailing 101
Last Post: 07-18-2016, 10:49 AM
Last Post: 08-29-2012, 11:07 AM
By fredcandetail in forum Auto Detailing 101
Last Post: 05-02-2012, 09:36 AM
By Dugdug in forum Tricks, Tips and Techniques
Last Post: 11-03-2011, 09:14 PM
By stove937 in forum Ask your detailing questions!
Last Post: 10-27-2009, 11:50 AM
