Page 3 of 16 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 152
  1. #21
    Regular Member ExpressDetail's Avatar
    May 2011
    New Orleans
    131
    Re: Headlight restoration 50/50.
    Very Nice outcome. Glad to see you use your noggin.
  2. #22
    Jan 2007
    Canyon Country, CA
    299
    Thats some sweet work right there. I need to try this out on my TSX headlights even though they are just slightly chipped. I remember when I used to have my performance shop and the bodyshop next door would throw away perfectly good headlights, I would go pick them up and restore them. They would look at me like I was crazy. Good job.
    MDetail (Mike/Michael)
    Canyon Country, CA (Valencia Area)
    MichaelSchoelen.com - Photography
  3. #23
    May 2011
    Daytona Beach, FL
    219
    Here are some lights I've done using Hotrods method.
    It seems the worse off they are originally, the better they look when your done. (Or, the more of the original coating that is oxidized, the easier they are to sand and the better they are when your finished) The ones I have trouble with are the ones that still have most of the original coating that is good but the top of the lense is oxidized and looks bad. The two used car lots I work with demand a swirl free look/finish. So far, I've been pains-takingly using a coarse grit to totally remove the "good" coating so that I can assure an even look across the whole lens. Another member advised me to try leaving the "good" coating alone and only try to fix the bad top part, then wet sand with 3000 the entire lens and apply a new coating to the whole lens. I have an expedition to do in the morning that only the top part is bad. I'm going to try this method to see if I can blend the good and bad parts without removing the "good" coating. Wish me luck. I unfortunately do not have the advantage of being a bodyman(sucks to be me...lol) just an 22 year auto mechanic.....lol (I hope these pictures show up on the post. My first time with this type stuff)
    Attached Thumbnails Attached Thumbnails Headlight restoration 50/50.-best-cav-before-jpg   Headlight restoration 50/50.-best-cav-after-jpg   Headlight restoration 50/50.-dscf1255-jpg   Headlight restoration 50/50.-dscf1257-jpg   Headlight restoration 50/50.-dscf1102-jpg   Headlight restoration 50/50.-dscf1105-jpg
  4. #24
    Super Member 93fox's Avatar
    Dec 2010
    Houston TX
    1,076
    Quote Originally Posted by Part-timer View Post
    This method without polishing is alot better. Im 100% sure its more effective and will hold on A LOT longer. Now what i really want to see is how long will they last before they turn yellow again... hmmm.
    Hi !
  5. #25
    Super Member Wills.WindowsAndWheels's Avatar
    Oct 2009
    Gilbert,az
    1,682
    Quote Originally Posted by 93fox View Post
    Well the guy who originally posted the spar urethane idea had posts up well over a year after first doing them with no problem and that was WITH compounding so we'll see...
    Wills - Windows & Wheels Auto Detailing Detailing LLC
    www.WindowsAndWheels.com
    'Like' Us On Facebook
  6. #26
    Dec 2010
    Houston TX
    1,076
    Quote Originally Posted by Wills.WindowsAndWheels View Post
    I am sure this method will last alot longer that compounding. After i tested this method, and compared it to the steps taken to paint a car, compounding just seems pointless.
    Hi !
  7. #27
    Super Member Rei86's Avatar
    Apr 2011
    1,087
    well keep us up to date with a new post in 2012
    Hello my name is Sean
  8. #28
    Nov 2009
    Pasadena, CA
    12,615
    Nice job, Oscar!
    I thought I read somewhere that you could apply the urethane after sanding with 1500 grit?
    '03 Corvette Z06
  9. #29
    Super Member C. Charles Hahn's Avatar
    Aug 2007
    Lansing, MI
    3,103
    Quote Originally Posted by 07 z-oh-6 View Post
    Nice job, Oscar!
    The spar goes on pretty thin if you reduce it down; I'd imagine you might need a couple coats for proper coverage. Haven't tried that yet.
    Automotive Clear, on the other hand, should fill 1500 grit scratches with relative ease.
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
  10. #30
    Dec 2010
    Houston TX
    1,076
    Quote Originally Posted by Rei86 View Post
    thanks for the tip! i sure will keep people updated!
    Nice job, Oscar!
    Thanks Mark! i have to try it at 1500 and see if any scratches are still visible. at 3000 grit there werent any sand scratches visible at all.
    Quote Originally Posted by Shiny Lil Detlr View Post
    Yes Charlie it is reduced. Its one part urethane and one part mineral spirits. it goes down super smooth and thin. so far only one coat covers everything and does pretty well with just one quote.
    On the other hand, automotive clear should be applied over 1000grit finish on headlights. 1500 is too risky for the clear to adhere well. Im sure it will lay down nice but the chances of it failing after time are high.
    Hi !
  1. Replies: 9
  2. Help with headlight restoration
    By jeorviene in forum Ask your detailing questions!
    Last Post: 05-20-2015, 05:22 AM
  3. My first headlight restoration
    By Goodys in forum Show N' Shine
    Last Post: 08-04-2014, 03:44 PM
  4. DP Headlight Restoration Kit vs Mothers NuLens Headlight Renewal
  5. Best Headlight restoration kit
    By Grifffx4 in forum Auto Detailing 101
    Last Post: 04-13-2014, 09:44 PM
