Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Junior Member ANeat's Avatar
    Nov 2010
    SW Ohio
    70
    Birds vs Rotary (New guy with a Rotary)
    Hello everyone, my first serious attempt at anything resembling "correction" past your basic wash/wax.
    Something Ive been wanting to do, and have been reading up here quite a bit.
    Anyway, starting small with doing the hood on my 2002 VW Golf TDI. typical pseudo neglected 8 year old daily driver with 150k miles. (Black)
    I always thought the paint looked pretty good but the years have done their thing.
    At some time Ive gotten several bird droppings on the hood that have etched pretty well and the typical washing/waxing wasnt doing anything.
    So after washing and claying my regiment was 105/205 using Meguiars trio of foam pads, purple pad for the 105 and yellow for the 205. I used the black pad to work in the wax (NXT)
    My plan was to use the foam pads to reduce the risk of any beginners errors that the agressivenes of a wool pad might cause
    Buffer is a Makita Rotary (used with caution)
    The places needing fixed.
    So I misted a little quick detailer on the purple pad, applied some 105 and proceded to have at it.
    This next shot was where I think one of the "etchings" were located. This is just after the first pad and the 105
    So I carried on with the 205 and the wax, and man what a difference
    I know, its just the hood, but hey, following instructions works Now Ill have to do the rest
    Adam
    Super Member DetailedByPrecision's Avatar
    Sep 2009
    SF Bay area, Cali
    807
    Re: Birds vs Rotary (New guy with a Rotary)
    looks awesome but why the orange pad with 205???
    Super Member BobbyG's Avatar
    Dec 2009
    Southeast, MA
    13,211
    Hey Adam, Welcome to Autogeek!
    For a first timer I think the results are awesome! While some of your approach seems a bit aggressive, you've demonstrated that varying pads with the same product can achieve outstanding results.
    For pad and compound selection Meguiar's M105 is generally used with a course cutting pad like purple, yellow, or orange. These pads are firm and dense enough to allow the product to do it's job effectively and quickly.
    Products like Meguiar's M105 and Menzerna Power Gloss are in the area of removing scratches and swirls with a minimum sanding grit of approximately 1500.
    Both Lake Country purple and yellow pads
    "Use these pad to apply compounds or polishes to remove severe oxidation, swirls, and scratches. It is the most aggressive and should only be used on oxidized and older finishes. Always follow this pad with an orange or white pad and a fine polish to refine the paint until it is smooth. "
    Orange pads
    "Firm, high density foam for scratch and defect removal. Use this pad with polishes and swirl removers. It’s an all around pad that will work on most light to moderate imperfections."
    White pads
    "Less dense foam formula for the application of waxes, micro-fine polishes and sealants. This pad has very light cutting power so its perfect for pre-wax cleaners."
    Autogeek Buffing Pad Comparison Chart
    Keep up the good work and post more photos when you're through!
    Aug 2010
    New Jersey
    15,167
    I think you guys are misunderstanding...the OP said he used MEGUIAR'S pads...sounds like the Softbuff 2.0 pads. When he said "purple" he meant the burgundy cutting pad, yellow was the yellow Meguiar's polishing pad, and black was the finishing pad. For that line, I think he used the right pads...and you can't argue with the results (although I don't know how much paint came off ).
    Super Member bmw5541's Avatar
    Jul 2009
    Flanders, NJ
    334
    was thinking the same thing.
    Great job for a newbee Adam!!
    Barry Schultz
    DETAILED ELEGANCE
    Nov 2010
    SW Ohio
    70
    Hopefully just enough
    Thanks guys, yes I was Using the Meguiars Softbuff pads. Meguiars Soft Buff 2.0 7 Inch Foam Pads 3 Pack - Your Choice!
    All the pads and products can certainly be confusing and you can imagine how a new guy must feel.
    Adam
    Quote Originally Posted by ANeat View Post
    You did great for a new guy...
    The pads and products of this trade can be confusing but with a little reading and discussion after a while everything starts to fall into place and then it makes more sense.
    I remember the first time I was introduced to the Meguiar's Professional Line and the guys showing me this stuff kept talking about "Numbers" like it was a second language and that's because numbers and terms for products in this industry are a lingo of sorts...
    Nov 2010
    SW Ohio
    70
    Thanks again; Im getting more familiar with some of the lingo the more I read.
    I was really glad to see the etching get polished out but the clarity that returned kind of suprised me (in a good way)
    I have no plans be a professional but with all the info here hopefully I can keep my vehicles a little better looking
    Adam
    Dec 2009
    Southeast, MA
    13,211
    You guys are spot on, I stand corrected! Pay no attention to the man behind the curtain!
    Still, a fabulous job with stellar results!
  10. #10
    Nov 2010
    SW Ohio
    70
    Got a little sunshine today
    Adam
  1. Replies: 23
    Last Post: 01-23-2019, 04:45 PM
  2. Replies: 2
    Last Post: 08-20-2018, 08:00 AM
  3. Replies: 15
    Last Post: 12-05-2016, 09:10 AM
  4. The Flex PE14 Rotary Polisher - The rotary I grab first...
    Last Post: 09-08-2015, 11:48 AM
  5. new to rotary polishing..no rotary polisher..
    By Qusai in forum Auto Detailing 101
    Last Post: 10-24-2012, 04:59 PM
