Detailed: 2009 Nissan GT-R White Pearl
This vehicle was a recent purchase by it's owner and the goal was to get it back to like new/perfect condition. When the car arrived, we discovered it's poorly installed clear bra and the owner had decided he wanted it removed prior to arrival. The GT-R has a significantly harder clear coat than most production Nissans, making it more resistant to marring/swirling. With that said, the paint was not in desperate shape, but had it's fair share of defects. So we went top to bottom with this car to make it better than new. The white pearl color really sets the new GT-R off!
Process: car was degreased with P21S TAW, washed with CG citrus wash. once it was off, did test panel and decided it needed wool pad to get rid of all defects. whole car was done with wool pad and menz 203, then followed with menz 203 and orange pad and finished with menz 106 and white pad. then p21s paint cleanser. wet diamond sealant was applied and left overnight to cure. took it off in morning. rinsed the car and applied Wolfgang Fuzion wax. wheels and brake calipers were sealed with Rejextires were dressed, inside received quick vacuum since it was in great shape. wing was not removed due to double sided tape on most of 3 mounting points, didnt want to brake it either.
products used:
Menzerna 203 - Purple wool
Menzerna 203 - Orange
Menzerna 106FA - White
P21S TAW
P21S Polishing soap
P21S paint cleanser
CG Diablo wheel gel
CG MetalWax
Rejex
Black Fire Wet diamond sealant
Wolfgang Fuzion wax
im sure im forgetting others
as car arrived:
poor quality clear bra was taken off per owners request (took 20 minutes, didn’t even need heat gun, it pealed right off with minimal effort). Worth installation quality we have seen, but at least no visible razor cuts
car was then taped off
Exhaust Before
Exhaust After
Headlight Before/After
A Pillar Before/After
Wheels before and after
Paint Defects found under halogens( pics were taken after menz 203 and wool pad before all finishing polishes)
Re: Detailed: 2009 Nissan GT-R White Pearl
Great work on the car!
The HDR pic's would have worked better with the lights just behind you(just over your shoulder's), with a slight upward direction.
awesome work! I wish I had the opportunity to work on a car like this...
2011 Nissan Xterra Pro-4x: Avalanche White
2006 Nissan 350Z Touring 6MT: Redline Red
still learning camera stuff, deff will try that when car comes back for winter prep
Great work.
HDR isn't easy. I have had very mixed results myself.
Wow a wool pad? I wonder if the white paints are different from the black paints...because I have noticed the GT-R paints do not respond well to heat and marr rather easy. Overall though that is a slick looking job!
Mike - Mirror Detailing - Powder Springs, GA
R.I.P. Matt Eddy(SouthrnStyle) 11/26/2010
Originally Posted by Rob T
Great work.
I have been playing with HDR ... any chance you can post your bracketed pictures for some of us to play with?
They are pretty big RAW files, but let me see what I can do..
By noslef in forum Show N' Shine
Last Post: 09-08-2015, 08:28 AM
By lawrenceSA in forum Show N' Shine
Last Post: 04-03-2014, 01:59 AM
By sportscarhiatus in forum Show N' Shine
Last Post: 03-15-2011, 10:48 AM
By 1MZsLastForever in forum Show N' Shine
Last Post: 01-19-2011, 06:59 PM
By Dust2Glory in forum Show N' Shine
Last Post: 07-02-2007, 08:06 AM
