Here is a 2008 Silverado. The truck was pretty beat up and had some pretty good scratches in it. It was an exterior only detail that took me about 10 hours to complete.
Process:
Clayed entire truck using Final Inspect as clay lube. M105 on double sided wool pad. Followed by 1 pass of M205 on a green flex pad than 1 pass with 205 on a white LC finishing pad. Then I topped wih 26. The tires were dressed in ASD and the plastic trim was done up with HD 2:1 as well as the wheel wells.
Before:
After:
Thank you for viewing.
