This was done back in the summer. Thought I'd post it up here since I'm back.
Here' is the process.......
Engine Bay......
The engine was sprayed with ZEP's Industrial Degreaser at 4:1. I let it sit for 5 minutes while I washed all of the under the hood paint by hand. I then "steamed" the bay. Man it's nice to have a steam pressure washer. Once dried, the plastics were treated with Meguiar's Hyper Dressing (4:1) while all painted areas were cleaned and protected with Meguiar's D-151 Reconditioning Cream.
Wheels, Tires, and Wells......
The wheels were first treat with Meguiar's Wheel Brightener at 4:1. I had a least an hour devoted into each wheel. I used 3 different brushes then pressure was with steam. Once dried, they were cleaned and protected with DuraGloss' #501.
The tires and wells received ZEP's Industrial Degreaser at 4:1. They were brushed then dried. The wells were sprayed with Meguiar's All Season Dressing. The tires were treated with Tireific's long lasting tire coating. It dried hard and has last six weeks on my personal vehicles and threw numerous washes.
Paint Compounding......
(Meguiar's #105 (DA) via G110 & LC's Lo Pro Orange 5.5 pads)
This was a long process. I used Kevin Brown's process but the paint was bad. It took three passes on the hood alone........and it's a big hood.
Here are a few shots of 105 at work.....
Paint Polishing.........
(Meguiar's #205 & D-151 via G110 & LC's Lo Pro Black 5.5 pads)
No, I didn't use them at the same time. I used 205 first and then came back over the paint with D-151 for added protection and to ensure and flawless finishe. 205 can be stronger than you think. D-151 compliments it very well and I love the look it leaves. All glass was treated with it as well.
Paint Protection.......
Lusso Oro was the choice to top it with. This car will be garage kept and will be driven 1 a month so durability is not an issue. We wanted looks and Lusso handled it well. All the jams were coated with Lusso as well. The car's paint got 2 coats in all.
Interior.......
It was vac'd out and wiped down with Meguiar's APC at 6:1. The leather was treated with Lexol. Very underated in my book. The glass was treated with Stoner's Invisible Glass (liquid form). Very simple.
Before's......
Inside after the wash.......
Afters....
