Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Super Member Slava's Avatar
    Oct 2009
    Mile High City
    474
    Pic. Of Test spot
    My order ofKlasse kit came and and I decided to use the AIO and did a test spot on a 7 year old carbon fiber hood that has a lot of oxidation.
    I'm very pleased with the product so far. This was just a single pass by hand and you can see the difference.
    CORN FED STI
    Super Member sullysdetailing's Avatar
    Mar 2009
    South Florida
    1,963
    Re: Pic. Of Test spot
    Cant wait for the afters
    Shawn
    Sully's Detailling LLC - South Florida
    www.autogeek.net
    From the picture you have an uncoated CF panel and what you're seeing is oxidation.
    Saw a lot of this in SoCal mostly because the people that sell all the young guys these components don't tell them how to take care of them and that's likely because the manufactures don't know either? I guess everyone thinks a CF component will just look good forever with no care?
    Regardless... when removing oxidation use your product heavy or wet, you want plenty of chemical cleaners in the AIO working for you.
    Afterwards, be sure to seal it really well with the SG. Don't wash with cheap soaps or any type of detergent soap like dishwashing soap as Carbon Fiber Components, just like single stage paint and gel-coat finish are prone to oxidation.
    If you find the AIO not aggressive enough then I've restored a lot of CF using M80, any CF, gel-coat or oxidized single stage paints really likes the rich oil base in the M80 Speed Glaze.
    p.s.
    Good job on the Test Spot, that's exactly what is mean by doing a Test Spot, working on just a small section to dial-in a successful process.
    Oct 2009
    Mile High City
    474
    Mike,
    Thank You for the great advise.
    Before work I got few more passes on the test spot and it’s night and day.
    Here’s a picture of me of the test spot from last night. Following the instruction by Klasse (a little goes a long way) and it did but I still wanted more.
    This's from this morning did an up close pic.
    3 passes with a lot of AIO, and a lot of pressure onto the MF applicator. Using the
    Had to push the car outside just to see what it looked like.
    This is only a 3x3 or so test spot and I know that if I used a polisher I'd get better result but for now I'm very happy with it.
    CORN FED STI
    Super Member dublifecrisis's Avatar
    Mar 2008
    Jacksonville, Fl
    1,158
    "night and day" as you described pretty much sums it up. did you do the rest of the car yet?
    Oct 2009
    Mile High City
    474
    Quote Originally Posted by dublifecrisis View Post
    Not yet. This is just the test spot. I won't be doing much this week as it's supposed to snow tonight and temp. will drop below freezing.
    CORN FED STI
    Super Member DLB's Avatar
    Jul 2009
    Ringgold, GA
    1,211
    Great job! Difference looks amazing!
    DLB
    Oct 2009
    Mile High City
    474
    I used Brinkmann Swirl Finder Light in this pic and I think that it makes the CF look a lot better then it really is. But still much better then before.
    CORN FED STI
  10. #10
    Super Member gewb's Avatar
    Oct 2008
    Denver, Colorado
    562
    Quote Originally Posted by Slava View Post
    I'll bet it does look like that...a Brinkmann can't make a silk purse from a pigs ear!
    Regards,
    GEWB
    (Denver)
    Linux Reg. User #206357 (Feb. '99)
    "Can't get there from here."
  1. How To Do a Test Spot
    Last Post: 09-24-2019, 08:41 AM
  2. Only one test spot?
    By Carlito12200 in forum Auto Detailing 101
    Last Post: 04-29-2016, 08:43 AM
  3. How to do a test spot???
    By runrun411 in forum Auto Detailing 101
    Last Post: 08-04-2015, 04:54 PM
  4. Test spot
    By BennyHFP in forum Auto Detailing 101
    Last Post: 05-19-2015, 08:22 PM
  5. Doing a Test Spot....
    By HUMP DIESEL in forum Auto Detailing 101
    Last Post: 11-20-2014, 02:56 PM
