08-20-2014, 01:25 AM
#1251
Re: Headlight Restoration-new UV sealant idea
Originally Posted by melF1fan
I've been using the Glasweld GClear - I don't blame them for not wanting to warranty as there are too many variables they cannot control.
I will say that it will last at least a year and many years if you follow the instructions spot on. Preferably indoors out of the sun. Then either UV cure lights or park out in the sunlight for 10 minutes. Also, if you have experience with Spar, the appliication after sanding is nearly the same possibly even easier but you need to be careful as it will start to harden after you wipe on. It fills and hardens to a much thicker coating than Opti Lens. The product comes with detailed instructions. I say go for it as i had the same contemplations as you did.
Good luck
awesome thanks!!.. im def gonna place an order now and give it a shot. great to know this stuff lasts at least a year. crazy how this thread has gone on for over 120 pages and this product has yet to be mentioned considering you get 6x the amount for less then the price of opticoat/lenz.. and yea i guess it is reasonable for them not want to warrant the lights for my customers since they are still technically my customers and legally that could be tough to do.
I was told you can get up to 16 cars for an 8 ounce bottle($44).. which comes out to like $2.75 a car(very affordable).. Do you really need half an ounce for each car? that seems like ALOT of liquid to use for only two headlights
08-20-2014, 06:55 AM
#1252
They seem like a pretty new company and the headlight product may be even newer--they only show 19 applicators in all of North America (including Canada and Mexico), and they are all listed as windshield repair. In comparison, Optimum has twice that many installers for Opti-Coat in California alone.
08-20-2014, 11:55 PM
#1253
The cost per vehicle of all three coatings you mention are in the same ballpark... around a buck per vehicle depending on how you work with it exactly. Optilens is much more expensive per ounce, obviously. But the cost per vehicle is actually the cheapest in my experience because so little product is used per application.
GClear is more difficult to use than the others, because of the UV curing factor, and takes more skill to apply correctly without screwing it up. Sort of a high-risk, high-reward. You have one shot to get it right, or it's a lot of work to remove and reapply. It is very similar to using spar, but it's not so easy to fix mistakes. Much better if you get it right the first time, so practice a bit. Nice heavy coat, without getting runs. BTW, as mentioned, it's best to apply out of the sun... and is more difficult to apply on hot surface.... simiar to using high ratio of spar-ms.
Infinity is more forgiving, easy to apply, air dry etc. But it's not quite as crystal clear IMO and you need to do more prep to the lens... fully restored, clear. (same thing with Optilens btw) Done right, it's way better than spar varnish. Looks better, lasts longer, easier to use.
FWIW, I've actually seen the UV cure coatings break down within a few months... but that's not normal. I'm doing dealer work and sometimes... don't follow suggested directions and often experiment with things, so sometimes I mess with the process a little too much. Overall though, Infinity and Gclear are both a dramatic improvement over wood varnish, which is almost guaranteed to fail within a year. Be shocked if it doesn't.
08-20-2014, 11:56 PM
#1254
Their headlight stuff is pretty new... but the company has been around at least 20 years in the glass biz
08-21-2014, 07:33 PM
#1255
thanks for the response to my original post first off.
Going back to the price, gclear is $80 for 16 ounces(32-40 cars) where opticoat you can get 20c(2/3 of an ounce) on amazon for a little over $70 so gclear def sounds like a better buy if the stuff holds up. I coukd be wrong but it seems like it would be tough to coat 32-40 cars with less then an ounce of liquid, although it could defenitly be possible.
Also I'm still not getting why gclear is so much more difficult to apply then the spar? I mean as long as your not in direct sunlight the liquid shouldn't start curing right away.. right? I was told a heating source isn't necessary becuase the light only Take 10-15 to cure in the sunlight(which is awsome). I was also told directly from one of the chemists who produced the product it heat should not affect the sealant but applying it within direct contact of the sun can and will(cause it to streak). Im guessing that gonna be the issue regardless. Anyhow, It should be arriving tomorrow so I'm gonna run some tests(cure time, how it reacts with water, oms, heat, compound/polish, etc) on an old car I have first before I start using it.
I agree anyone who is still using spar as a clear coat should really think twice about garunteeing a year warranty with that stuff. I learned the hard way and have already had to drive ba ck and redue several customers cars. It's not worth it.
08-21-2014, 11:41 PM
#1256
Urethane coating is completely different than Optilens, enough that it doesn't make sense to "cross shop" them. OL only takes a few drops per lens...
Anyway, with all of the coatings, part of it is how efficient you are. A lot of it can be wasted, depending on the applicator used, etc. So one guy might get twice the number of cars as another guy, from the same product. I've found the mfg estimates are often reasonable, but are conservative. They surely would prefer if you used/wasted a little more product vs. being efficient and making the bottle last longer, if you know what I mean. The 16oz Gclear can easily do more than 40 cars, especially if you do often do more than one car at a time... or can keep the applicator clean and stored so that it can be reused a few times. Their applicator works great, but soaks up a ton of product.
Here's why I say it's more difficult. On hot days and/or in direct sun, it tacks up very fast so it's tricky to apply on a larger or odd shaped lens. Cooler weather or working inside does help a lot. It's definitely easier inside, completely away from sunlight. That also allows the coating to flash a couple minutes prior to curing with a light or moving the car out in the sun. On really humid days, there can be some blushing.... which will disappear in a couple minutes as long as you keep UV away. The other reason it's more difficult... is just that it can be a nightmare to fix if you screw it up the first time, compared to spar varnish.
08-22-2014, 12:23 AM
#1257
do you think its best to measure out the liquid before applying or do you just need to saturate the applicator pad completely? also do you think the blue shop towels would work well?
hopefully my wondershade will provide some coverage from the sun. If you do screw up, im guessing you would have to resand with a 1500?(maybe 600?). the guy i talked to mentioned you could dilute gclear(was told to dab the aplicator pad in IPA) to make it easier to spread so maybe that could be used to remove it?
08-23-2014, 08:06 AM
#1258
I think it's a good idea to measure it.... at least a few times, so you know how much you are actually using per car.
I use a small tupperware type container as a dip tank. Pour a little into it... whatever I think is needed for the job. I also use it to store the applicator between uses. Keeps it sealed, out of sunlight... helps if you want to reuse it. Putting the applicator in a Ziploc bag with air squeezed out is even better for storing for next day/week.
Blue towels work ok, but they need to be soaking wet... and takes a lot of product to get enough of it soaked to do a large lens in a single step. I would recommend trying the applicator they sell for gclear. It really does work nice. Don't soak the whole thing like in their video.... just use one end or corner of the pad.
I will have to experiment more with removing the uncured product with solvents. I would think the best thing would be urethane reducer. IPA sounds odd to me. I've used 600 grit to remove it. Don't think 1500 would cut it unfortunately. If you catch it immediately, wipe down with thinner/ipa and resand the final step.... 1500-3000 grit.
08-28-2014, 09:24 AM
#1259
I've been out of the business for 2 years. We developed a chemical stripper to eliminate most sanding and 2 different hard coats; a 2 part poly coat and a conventional varnish based coat.
We never fully went into production because the market is so fragmented and production costs for startup were so high.
Here's 2 videos we produced:
https://www.youtube.com/watch?v=oBtl68SlcBc
https://www.youtube.com/watch?v=_hzcelTUvJo
There are many protective coatings available today; far more than when we were looking at the market.
One reason no one wants to talk about coating lifetime is that it's really a question of environment. You could coat a restored headlight with simple auto wax and it could last years if the car is parked in a garage. Conversely, you could use a very expensive UV cured coating that might start yellowing in a few months if constantly exposed to sunlight.
It might help you choose a coating if you understand the science behind these coatings. I'm working on a post that I'll post next week that explains the science of these coatings.
08-29-2014, 12:51 AM
#1260
Glad to see you back ray6.
By geoguy in forum Show N' Shine
By ShineTimeDetail in forum Show N' Shine
Last Post: 06-08-2012, 09:47 AM
By websdown in forum Auto Detailing 101
Last Post: 02-03-2012, 02:19 PM
By truckbutt in forum Auto Detailing 101
Last Post: 08-21-2011, 08:57 PM
