08-03-2023, 04:33 AM
#871
Re: DFB's Garage
[QUOTE=Danube;1778098]
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by DFB
Ahh sorry, no oil filter on those engines, rather the air filter foam element is soaked in oil to trap dust.
Standard procedure is to take the filter out of the housing, wash out in soapy water (not petrol or a solvent), allow to dry and then re-oil before putting it back into the housing. I just buy a new foam element, you still need to oil it though. Not too much, just enough for it to be sticky. Best way to do it is to put the filter in a small plastic bag, add some oil to the filter and then scrunch/squeeze the filter in the bag to distribute it, this will also remove any excess. QUOTE]
Well, mine doesn't look that bad for not being cleaned that long ...
Attachment 76889
For $5.60 is no brainier to replace it however I opted for washing with this miracle APC at the cost of $1.75 from Aldi (please try it and let me know)
Attachment 76890
Good work. Don't forget to re-oil it before to put it back into the housing.
08-03-2023, 04:38 AM
#872
Re: DFB's Garage
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by Prange
If you get a chance, check out Olsa for tools and organizers.
I've spent far too many hours trying to find something that I like and/or I can actually buy. Too many options, too many that are not financially viable. One of those included Olsa, which also carry Tool Grid, which what I really want because of the clean look of the setup. But, to buy what I need is equal to the price of shipping to Australia.........we're talking four figures by the time it lands at my door. ![Wow!](https://www.autogeekonline.net/forum/images/smilies/eeek.gif)
I've decided on something a little more basic for now, and I'll see how it looks once I've played around with the layout.
08-03-2023, 07:37 PM
#873
Re: DFB's Garage
Four figures, wow. Might as well be four fingers. Not worth it to me, either.
DFB liked this post
08-04-2023, 03:18 AM
#874
Re: DFB's Garage
Washing and oiling went well, good to go for another century.
A freezer bag worked fine for evenly spreading the oil.
While there I also checked the head bolts, no tightening required, all good.
This little Honds bugger from the photo is giving me some headaches lately - when the trigger is full on, it always tends to die. Less RPM's no drama, full on - it dies.
I've changed the spark plug, also shortened the fuel hose to avoid kinking .. no changes at all.
Any thoughts DFB ?!?
Flex 3401 & PE14
![](https://www.autogeekonline.net/forum/image.php?u=40275&type=sigpic&dateline=1331292609&s=0105c3ca52d431bdeab91a4d1b66a557)
08-04-2023, 03:44 AM
#875
Re: DFB's Garage
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by Danube
![DFB's Garage-1-vippa-jpg](https://www.autogeekonline.net/forum/attachments/show-n-shine/76891d1691137106t-dfbs-garage-1-vippa-jpg?s=0105c3ca52d431bdeab91a4d1b66a557)
Two things come to mind -
- First, a blocked exhaust port or spark arrestor in the muffler. This is mostly applicable to 2-stroke engines, but it you don't run the machine at full or high revs often, the carbon doesn't burn off properly and eventually causes it to build up and block, ultimately preventing the engine from exhaling.
I haven't pulled down a small GX25 / GX35 Honda before, but you would need to inspect the small muffler outlet screen, which your unit may or may not have as there are a few different designs for these engines. Remove any built-up carbon with a wire brush or by heating it with a flame and again agitating with a brush.
![](https://i.postimg.cc/W1Jkq8qG/gx25m101.png)
![](https://i.postimg.cc/FK5JyS02/gx25m102.png)
For the exhaust port, you will need to remove the muffler and inspect the port for carbon build up. Remove by gently scraping the carbon away. In both cases, you will need to remove the engine shrouding. While the muffler is removed, make sure the inlet is not blocked either.
![](https://i.postimg.cc/DyNGzH0f/gx25ep101.jpg)
- Secondly, it could be that engine is not getting enough fuel at full throttle. In which case, check the fuel filter in the tank. Otherwise, you will likely need to rebuild or replace the carb. These are a diaphragm carb, which become hard with age and don't pump fuel properly. Usually, you will have starting issues as well. On my GX25 powered Atom Edger, I had the carb rebuilt and fuel line replaced to solve this issue.
08-04-2023, 08:28 AM
#876
Re: DFB's Garage
Thought of you yesterday deyon(wierd sounding...i know lol) after mowing the grass, i hosed off the garden tractor and it it was beading like crazy. Forgot i wiped it down with something at the begining of the year. Didnt have the phone to take a beading shot lol
But i thought...i wonder if all of deyons mowers bead water lol
DFB thanked for this post
08-05-2023, 03:16 AM
#877
08-05-2023, 05:24 AM
#878
Re: DFB's Garage
New car?
08-05-2023, 05:39 AM
#879
Re: DFB's Garage
New car?
![](https://i.postimg.cc/jS4MCxzz/IMG-9082.jpg)
Nice, I've always liked them, but I'd never own one.
08-05-2023, 05:44 AM
#880
Re: DFB's Garage
![Quote](https://www.autogeekonline.net/forum/images/autogeek/misc/quote_icon.png) Originally Posted by Big Dave
I've always liked them too................and wouldn't dare own one either. This particular example has caused the owner a LOT of headaches over the years.
By Matador in forum Auto Detailing 101
Last Post: 08-11-2021, 06:22 PM
Last Post: 02-17-2015, 11:14 AM
By Mike Phillips in forum Off-Topic
Last Post: 09-17-2010, 09:47 PM
Last Post: 06-28-2010, 03:05 PM
Last Post: 06-23-2010, 01:00 PM
Members who have read this thread: 90
- John U,
- Vegas1,
- brianshaeffer,
- chilly,
- scottlee,
- BTW574,
- Rsurfer,
- VISITOR,
- chefwong,
- Karl_in_Chicago,
- Bunky,
- bill walsh,
- ollever,
- 02whitetundra,
- jrose0070,
- gibby68,
- tomsteve,
- Wknd Dtlr,
- Bobby B.,
- TroyScherer,
- Setec Astronomy,
- Jplouch,
- JSkibisky,
- WillSin865,
- georgia boy,
- hansen97,
- delt1964,
- vaced,
- donb,
- ajdavies91,
- D.BRITT,
- Danube,
- nashvegas,
- DG3.7,
- Ace22,
- Azure,
- The Guz,
- wierdkid,
- Alansr,
- Desertnate,
- ellens2,
- swiftjr,
- T-STeve,
- rmtaylor51,
- 11Silverado,
- no cigar,
- FocusSTguy,
- gregory1420,
- jvanseeters,
- 2FORDS,
- Texchappy,
- tradecraft1,
- oneheadlite,
- cyclops,
- RippyD,
- Dynoguy,
- Rollo,
- Prange,
- SNP209,
- JObucina,
- Tasmania,
- damonb10,
- 4getgto,
- chris87,
- pdl2mtl90,
- larr12,
- bradp674,
- Mklauss,
- DFB,
- Innovator,
- Odrapnew,
- msharpe785,
- dbeng,
- Avadesh Nathan,
- Silly Rabbit,
- Thunderchicken,
- chris12,
- Bosko,
- DanaDetailingPros,
- cb804,
- Optimus Grime,
- Dirty Harry,
- aannatshlzea6696,
- kappy,
- eveausasdy529,
- bapatickmjnra7168,
- filhotran,
- Awickedtruth,
- CarlosAcugh,
- tgndynamite
26 | 27 | 28 | 29 | 30 | 31 |
