Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    2020 C8 Corvette Detail by Mike Phillips
    Here's the 2nd black 2008 C8 Corvette I detailed in 2020. This car had 91 miles on it when it arrived to Autogeek. It was covered in Type II Water Spots - Imprint Rings. There were also a number of other paint defects that I'll share later.
    The paint on the black versions of this car is SOFT. I wouldn't call it super soft but it's definitely the opposite of hard. I corrected all of the defects and later removed sanding marks using only Dr. Beasley's NSP 45 and a RUPES white foam finishing pad on the CBEAST.
    I chemically stripped the paint using IGL Precoat and then installed one application of BLACKFIRE BLACK EDITION. Flash time before wipe-off was about 30 to 45 seconds.
    I polished the glass using the same products used on the paint then sealed the glass with PBL Surface Coating. The leather interior was sealed using PBL Leather & Vinyl Coating.
    Ready to drive home...
    There's a video on my Facebook page somewhere - in it I talk about what a pain these cars are to machine correct and polish simply because there's not a single large flat panel on them. The body panels are all made-up from multiple, multiple planes. Not a big deal but they do take more technique when running the polisher. Basically you make linear passes instead of crosshatch passes.
    Thanks for looking.
  2. Thanks Craig Encinitas, yello430 thanked for this post
  3. #2
    Re: 2020 C8 Corvette Detail by Mike Phillips
    More...
    You can see some before pictures and videos here,
    Water Spots in Brand New C8 Corvette - DOCUMENT PRE-EXISTING DAMAGE
  4. #3
    Mar 2017
    Mike whats the rpm speed you run the Flex at ?....i have dewalt i'll get the pads from you ...thanks
  5. #4
    Super Member Craig Encinitas's Avatar
    Jul 2020
    312
    Question:
    You chemically stripped the paint after using NSP 45. Do you feel that the SiO2 primer coat it leaves after polishing survived the chemical stripping before coating it with Black Fire?
    I’m trying to adjust my process with the NSP line, as I have all of it. Thanks!
  6. Thanks Jacob Harrod AUTOCLEAN thanked for this post
    Likes Jacob Harrod AUTOCLEAN liked this post
  7. #5
    Quote Originally Posted by kgs365 View Post
    That’s a cordless BEAST.
    See the blue tape around the trigger?
    That’s to keep the pedal through the medal.
  8. #6
    Quote Originally Posted by Craig Encinitas View Post
    Question:
    I hate typing on my phone / wait till I’m behind a keyboard and I’ll tell you what and why.
  9. Likes Mike Hoekstra liked this post
  10. #7
    Just rained...
  11. Likes Craig Encinitas, axel06, DFB, firecorgi liked this post
  12. #8
    Junior Member zvez's Avatar
    Jan 2015
    32
    man I wish I could afford a C8!!
  13. #9
    Super Member Sizzle Chest's Avatar
    Apr 2011
    Naples, FL
    5,900
    Looks great Mike!
    Scott Harle
    Autodermatology
    #autodermatology
  14. #10
    Super Member axel06's Avatar
    Oct 2012
    Fords, NJ
    883
    great work Mike
  15. Thanks yello430 thanked for this post
    Likes yello430 liked this post
  1. Replies: 27
    Last Post: 04-01-2021, 01:14 PM
  2. List of cars detailed in 2020 by Mike Phillips
    Last Post: 07-18-2020, 11:04 AM
  3. 2020 Detailing Class Schedule - Dates & Locations - Mike Phillips Autogeek
    By Mike Phillips in forum 2-Day ROADSHOW Car Detailing Classes - Info & Dates
    Last Post: 12-09-2019, 04:07 PM
  4. 1971 Corvette Original Paint detailed by Mike Phillips
    Last Post: 05-20-2019, 03:29 PM
  5. 67 427 Corvette Thanks Mike Phillips!!!!
    By Justin at Final Inspection in forum Show N' Shine
    Last Post: 08-19-2017, 05:09 AM
