Supercharged Mustang, 2500 HD, Explorer ST
Had a new customer drop off his black 5.0 Mustang for correction and coating.
Wash/Decon
Hyper wash, Nanoskin fine grade towel
Wheels/Tires
The Weld Racing wheels were a bit hammered and really need full aluminum restoration. I just wiped them down and hit the tires with some Hyper dressing
Correction- Rupes 21 Mark ll, Yellow IGL Foam pad, IGL F1 with a drop of 3D ONE. Flex PXE was also used
LSP- IGL Poly
Next was a 2500 HD Work Truck. This had some different repainted panels that required different approaches.
Wash/Decon
Hyper wash, Megs Iron Decon, Nanoskin fine towel
Wheels/Tires
Foaming wheel cleaner gel, Tire and rubber rejuvenator, Hyper dressing
Correction- Rupes 21 Mark ll, Some areas needed Uro wool with M100, Others only needed Yellow foam with IGL F1.
Finish Polish- Rupes 21 Mark ll, Yellow IGL Foam. 3D One
LSP- IGL Premier, machine applied with a black foam pad on low speed 21mm Mark ll
Next was a brand new Explorer ST in a sweet red metallic paint job.
Wash/Decon
Hyper wash, Nanoskin fine towel
Wheels/Tires
Wheels off coating service. Prepped with foaming wheel cleaner gel/Megs iron decon. Sprayed with IGL Eclipse industrial coating
Correction- One of the few new vehicles that really didn't need much polishing beside the piano black trim. Paint got a quick polish with 3D ONE, Flex XCE Cordless
LSP- IGL Quartz+
Re: Supercharged Mustang, 2500 HD, Explorer ST
Just what we always see coming from you Justin...EXCELLENT work! All turned out great. Love the pics as well...
Scott Harle
Autodermatology
#autodermatology
