Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Super Member WaxMaster1's Avatar
    Jul 2015
    Central Florida
    1,261
    Project 98 All-In-One Polish & Seal
    As one of the winners of the Project 98 giveaway, I received a bottle of the DP all in one. I had a 2016 Honda Civic to work on. It's owner gives it a swirl o matic every so often. It had light scratches and a a few deeper rids.
    Meguiar's Hyper Wash
    Nanoskin little red block with Meguiar's D115 @ 8:1
    DP All In One
    Great cherryish scent. Easy to work with and didn't dry up. 3 section passes with light pressure using my new Griot's Garage G9. Removal was super easy as well.
    Bottom line I definitely recommend DP All In One for ease of use and great results.
    DP All-In-One Polish & Seal is the advanced, multi-step product you have been waiting for. DP All-In-One Polish & Seal is designed to remove surface
    CHRIS Aka Waxmaster
  2. Likes MBC1965, PaulMys, DMiglio liked this post
  3. #2
    Mar 2011
    PA
    5,792
    Re: Project 98 All-In-One Polish & Seal
    That did turn out great!
    2018 Colorado ZR2
  4. Thanks WaxMaster1 thanked for this post
    Likes WaxMaster1 liked this post
  5. #3
    Super Member SNP209's Avatar
    Sep 2016
    728
    Great turn around, that civic cleaned up very well and those wheels came out looking great as well! Thank you for your review.
  6. Thanks WaxMaster1 thanked for this post
  7. #4
    Oct 2018
    Turned out great!!
  8. Thanks WaxMaster1 thanked for this post
  9. #5
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Awesome job Chris.
    How would you compare the DP with Speed?
  10. Thanks WaxMaster1 thanked for this post
  11. #6
    Jul 2015
    Central Florida
    1,261
    Awesome job Chris.
    Thanks Paul, I really want to use it on a black or darker car before I compare. It did a great job on the little Civic and it did make the metallic in the silver POP! I did want to try it in the sun, but I was leery and didn't want extra work in case something bad happened. LOL
    CHRIS Aka Waxmaster
  12. Likes PaulMys liked this post
  13. #7
    Jan 2014
    Eastern L.I. NY
    10,773
    Yeah, I guess the Silver isn't the best "acid test".
  14. #8
    Super Member DMiglio's Avatar
    Aug 2016
    Davenport, FL
    708
    This is a great product, even by hand it cleaned my paint up quite nicely! Wish I could’ve used a machine in my review but so glad you made this review. The paint definitely cleared up and the gloss was restored!
    Regarding the sun, I used mine in the sun and it really didn’t give me any trouble other than when I over applied bc it’s a bit tricky by hand. I’m sure you’d have no trouble whatsoever doing it by machine with a few passes and wiping.
    What type of pad is that? The side profile looks different from any I’ve seen..
    Alumni Autogeek's first ever Roadshow Detailing Class Oconomowoc, Wisconsin
  15. #9
    Jul 2015
    Central Florida
    1,261
    Quote Originally Posted by DMiglio View Post
    It is a Car Brite polishing pad which I believe I got from the outlet. There's a reason it was in the outlet. Project 98 All-In-One Polish & Seal
    CHRIS Aka Waxmaster
  16. Thanks DMiglio thanked for this post
  17. #10
    Jan 2014
    Eastern L.I. NY
    10,773
    Quote Originally Posted by WaxMaster1 View Post
    6.5" of disappointment?
  1. 1st Time DA Polish Project - Shadow Black Mustang
    By gatornek in forum Show N' Shine
    Last Post: 08-11-2019, 12:06 AM
  2. Sign-up: Semi-Secret Project Camaro - DeSwirl and Polish to Perfection!
    By Mike Phillips in forum Wednesday Night Detailing Classes - Info & Dates
    Last Post: 10-31-2014, 01:36 PM
  3. McLaren MP4-12C Project Alpha Polish
    By CarAudiophile in forum Show N' Shine
    Last Post: 05-29-2014, 09:09 AM
  4. my old wetsand cut and polish project
    By Gotafriendinpa in forum Wet-Sanding, Cutting & Buffing
    Last Post: 06-15-2013, 03:32 PM
  5. BLACKFIRE Total Polish and Seal before Crystal Seal ?
    By Nikhil from Dubai in forum Ask your detailing questions!
    Last Post: 04-22-2013, 03:50 AM
