Re: In-Progress: 1986 Porsche 951 (Guards Red)
Originally Posted by Dr Oldz
I’ve seen areas like that above in the body seams. I own/Owned classic cars so I’m kinda familiar with this issue. Usually it’s years of road film build up. I have had luck with products like prep-sol. If not, a compound worked wet with some make shift tool and a terry cloth may work. But work with caution.
I bought a 2nd set of wheels for my car that had something like this inside the barrels. It seemed to be impervious to anything (polish or tar remover). I suspect this is aged layers of tar and other oil based grime.
They wheels were clear-coated so I eventually took 4/0 steel wool and solvent to them to remove it, after trying everything else including sandpaper. I of course had to follow up with sanding and polishing. They were clear-coated and wheels, not the front of a car, so much lower risk. Not recommended here.
Huge change on that front end! It's amazing isn't it?!!
Dr O: thanks for that good info!
Scott Harle
Autodermatology
#autodermatology
Sorry it's been a while... There's been progress, just not a lot! Today's update is a duplicate of one from a couple of weeks ago. The lower rocker panel trim was damaged by someone not raising the car properly on a lift. To repair this, I had to pull the trim off, release the bend using a heat gun, and re-bend the metal bracketry. Then, a couple of reinstalls (to get it right) and it's back to normal! That should be the last of that type of job in this post hopefully. :-)
Click the pics to see them in full size/resolution
Quite bent "before"
Much better "after" (even the fender is a better color)
Much better! Keep this train a rolling!
Scott Harle
Autodermatology
#autodermatology
Loving this thread.....
Nice work, man!
Soooo.. it's been a while! I'm still here and still working on the car. Life gets in the way sometimes though. I'm still looking for an original red fender if anyone knows of a source, please PM me. I'm also looking for suggestions for a LSP. My goal would be to finish out the cut process and then do the car in panels: - polish, LSP, next panel - polish, LSP, etc... this way no polished panel needs to sit unprotected with my SLOW process. Suggestions are welcome!
Today's work:
Passenger's side door + mirror. I've been treating it the M7 for a while and finally got around to compounding it out tonight. It made a nice change. :-) Sadly, it revealed a dent in the door that I didn't even see before because the paint was so flat. I may be able to do something with it though in the future, so I'm not too worried.
Before:
After:
1 more panel and it should be all RED again! YAY!
Great work! And soon you are done with the cutting step corrected. The feel of the work and transformation you have accomplished I can imagine is a great feeling to have.
For the LSP I like the looks of Polish Angel products. It's a pricey brand but a little goes a long way with their products. If you are looking for a great wax I think Collinite 915 is a great looking one with a great longevity from it too. I like to go for the looks rather than the most economical ones. Not to say some economical looks good too. But I want great or awesome looking lol. It's not much that keeps them apart but that little extra gloss makes me smile
Awesome! McKee’s hi def paint sealant, Wolfgang Fuzion, hmmmm...
Scott Harle
Autodermatology
#autodermatology
By Oakes in forum Show N' Shine
Last Post: 12-17-2014, 12:48 PM
By TRex99 in forum Ask your detailing questions!
Last Post: 06-20-2014, 03:57 AM
By cleanmycorolla in forum Show N' Shine
Last Post: 11-18-2013, 12:22 PM
By Porsche Pilot in forum Show N' Shine
Last Post: 09-22-2011, 06:08 PM
By uniquedetailing in forum Show N' Shine
Last Post: 09-21-2011, 11:05 PM
