Results 1 to 5 of 5
    Super Member lawrenceSA's Avatar
    Feb 2012
    Durban - South Africa
    1,713
    Alpine White BMW M4 - Detailed by Lawrence
    Man what a nice car.
    Unfortunately it needed some love after having been maintained (the term is used loosely) through the local car wash. Its really mind boggling how much damage can get inflicted in such a relatively short time.
    So jumping straight in the first order of business was a cosmetic detail on the engine bay. No water was introduced. For the underside of the hood some Carchem APC @ 1:5 was sprayed into a MF towel and all the dirt wiped away. This was followed by working Dodo Juice Lime Prime into the painted areas using MF applicators by hand. The Lime Prime was left to haze then buffed off.
    Before
    After
    For the engine bay itself, the same wipe down process was used, and then the plastics were dressed using Carpro PERL neat. The carbon fibre piece was polished using a Shield DA, 4" Orange Lake Country pad and Menzerna 3-in-1.
    Before
    After
    Then it was time to tackle the fender wells, tyres, wheels and brake calipers which were all given an initial rinse with a Karcher K7 pressure washer.
    Carchem APC @ 1:5 through a Gloria Foam Master was used to clean the fender liners, tyres and the initial clean of the wheels. The tyres were cleaned a second time and the wheels then covered in TAC Systems Iron Zero, which was left to dwell before being agitated and rinsed. Any tar spots were removed using Carpro Tar-x.
    Before
    During
    After
    The tyres would later be dressed with Carpro PERL neat.
    With all the dirt work out of the way it was time to clean the rest of the exterior and decontaminate it.
    It had a bit of dirt on it so the exterior was pressure rinsed to get rid it of as much of this as possible.
    Even the exhaust tips looked quite sad
    It was then covered liberally in Turtle Wax Hyperfoam which was left to dwell before being pressured rinsed off.
    Then it was washed using Carchem Luxury Shampoo and lambswool wash mitts.
    The car was then covered in TAC Systems Iron Zero, which was left to dwell, then covered in some snow foam to extended the dwell time. As you can see, it bled like crazy - a sign that the surfaces were heavily contaminated with embedded iron particles.
    Visible tar spots were removed using Carpro Tar-x and any remaining contamination was removed using Shield Heavy Duty Clay with Gyeon Clay Lube. With the paint now bare, the thickness of each panel was measured in multiple places to ensure there was enough to safely remove the below surface defects. As you will see (especially on the hood, and (not depicted, a spot on the roof) there were a few places where deeper scratches were left behind in favour of the longevity of the paint.'
    The roof was not spared either. Sorry for the poor quality pic.
    No after shot - it was hard enough trying to get the before pic :lol:
    But there are at least a couple of paint correction pics.
    Before
    After 1 set of 8 passes using Menzerna SHC300 and Lake Country Blue Hybrid Foamed Wool Pads on the Flex 3401.
    After finishing with Menzerna 3-in-1 on Orange Lake Country Hybrid Foam Pads.
    The trunk lid before
    After (the same process as above)
    The exhaust tips were polished using Meguiars NXT All Metal Polish but sadly had already see too much corrosion from lack of proper maintenance to get them looking any better.
    Before
    After
    The exterior plastics and door rubbers were cleaned using Shield Heavy Duty Vinyl and Rubber Cleaner and protected using Carpro PERL. The glass was then cleaned with DNA-e Glass Cleaner.
    The paint and exterior glass were given a final wipe down using TAC System Quartz Max before the interior was cleaned.
    Brush
    Vacuum
    Clean the leather, rubbers and plastics with Carchem APC @1:20
    Damp wipe down
    Dry wipe
    Protect leather with Gyeon Leather Coat and plastics with Optimum Optiseal
    Clean the glass with DNA-e Glass Cleaner
    Vacuum
    The exhaust tips were given a quick polish with Meguiars NXT All Metal Polish
    Here are some pictures of the completed car.
    And my favorite pic...
    Total time spent = 36 hours.
    Thanks for looking and as always any questions or comments are welcome.
    :hi:
    Super Member Aaryn NZ's Avatar
    May 2012
    New Zealand
    1,930
    Re: Alpine White BMW M4 - Detailed by Lawrence
    Wow Lawrence, thats quite some turn around my friend.
    A pretty sweet looking ride too I must say. Crazy amount of iron contamination on the body work there huh, any idea if this BMW is parked by a rain yard, or some type of metal works? Super nice detailing under the bonnet Lawrence, not too many folks post up pictures of their engine detailing but your standards are always impeccable & it shows in every before & after picture you share.
    Fantastic post Lawrence, superb photos, write up & first class workmanship as usual.
    Aaryn NZ.
    a DETAILS Blenheim New Zealand - IDA Member - C.Quartz Finest Authorized Installer
    Feb 2012
    Palatine Illinois, USA
    24,624
    I love TAC Quartz Max, been using it as well as several other TAC System "toppers", not to mention their wheel cleaner and tire coatAlpine White BMW M4 - Detailed by Lawrence
    Great job as usual!
    2022 Elantra N Cyber Gray
    Nov 2017
    Excellent work. Looks amazing!
    Regular Member hilld's Avatar
    May 2014
    Camas, WA
    149
    I just bought a used Alpine White M4 and it pretty much looks like your before pictures. The only difference is mine is a convertible, meaning no CF roof, but more paint to polish. After looking at your pictures, there is home for mine.
    Thanks for posting.
  1. Alpine White BMW M3 - Detailed by Lawrence
    By lawrenceSA in forum Show N' Shine
    Last Post: 06-11-2016, 03:26 PM
  2. Alpine White BMW M5 - Detailed by Lawrence
    Last Post: 12-04-2015, 10:08 AM
  3. Alpine White BMW M3 - Detailed by Lawrence
    Last Post: 11-13-2014, 04:29 AM
  4. Another Alpine White BMW 1M - Detailed by Lawrence
    Last Post: 08-11-2014, 06:46 AM
  5. Alpine White BMW 1M - Detailed by Lawrence
    Last Post: 06-13-2014, 12:52 AM
