Re: Headlight restorations & feedback, please
You can get results within those with just an orange pad and the McKee's headlight restoring polish. No sanding. They look AWESOME man! Dont get me wrong.
Those look great--how many sanding steps did you do? All by hand or some by machine?
They look good. I started my real drive and interest in detailing 1-2 and now upwards of 3 vehicles per week on the side by showing off some simple headlight restores. My son helped out and we canvased our friends and neighbors and then word spread. I charge $50 per pair - $75 if I go to them and can knock them out pretty quickly. I agree that in many cases they can be done without sanding but for me its a huge time saving step to simply hit them with some 1500 and/or 3000 then polishing them back and sealing them up.
Thanks for the compliment, @ dcjredline!
I saw several great reviews of McKee's polish, but some of the lights i did were pretty BAD! Like completely frosted. Not sure if it would do those.
Also wanted some feedback on the Lake Country Foamed Wool 3.5 inch Buffing/Polishing Pad and how those 2 would pair up. If what "marketing"implies, it would be awesome. Often, real world differs from marketing dept, though!
Thanks again.
They awesome man, I normally can get away with 1500,3k compound polish. With out seeing in person it's hard to tell. I'd just keep doing what ur doing and see if u can get away with less steps. Keep up the work!
Setec - Thanks for the compliments. I was really happy (& customer / friend) with the job as well! For these really nasty ones (silver Rav 4), I probably used 400, 800, 1200, 1500, 2000(???) - wet, by hand - either with / w/o body sanding block. Then wet sanded w/ GG 3" & Mirka thru the rest of the kit (3k & 4k??) Then to the LC Blue w/ Megs Ult Comp & LC Orange w/ Megs Ult Polish. So, waaaaaay too many steps & time!
I was going to try DRY sanding for better cutting action on the earlier steps.
Holy cow, 7 sanding steps, and 2 polish? If you have to start at 400, I'd then go to 800 (dry), then switch to wet/damp for 1000, 3000, 5000. You should be able to finish from the 5000 with just polish. So that's 6 instead of 9 steps...not sure how much that helps.
I KNOW! Waaaay too many steps - that 1 of the big reasons for my posting.
I have used wet - not dry or damp sanding. That probably had too much lube for the sanding process - reducing cutting ability. Will def use LESS water!
TY again!
@pdqgp - Thx for your feedback. Sounds like you really did a grassroots effort to grow the biz! It's pretty cool that you have a "built-in" assistant!
My apprehension is about 1500 being aggressive enough
TY again,
- Allan
By TTQ B4U in forum Auto Detailing 101
Last Post: 03-26-2017, 12:26 PM
By g35_coupe in forum Show N' Shine
Last Post: 02-02-2017, 10:02 PM
Last Post: 12-30-2014, 01:49 PM
By mhphoto in forum Show N' Shine
Last Post: 06-26-2012, 05:30 PM
By Helljumper09 in forum Show N' Shine
Last Post: 08-05-2010, 03:56 PM
