2015 Avalon - 2-Step Correction, CarPro Essence and CQuartz TiO2
The owner of this 2015 Avalon has seen my work on a few other vehicles and requested for his car to be corrected and "coated." He was quite impressed by the dirt-repelling capabilities from CQuartz UK on my girlfriend's car, so he specifically requested for a similar product to be used on his vehicle.
Up until now, this vehicle had been washed by a local "hand wash" car wash. There are many of these places in Southern California and the quality of their work can vary significantly. Clearly, the one that has been maintaining this car has done some serious destruction to the finish!
After a wash using Meguiars Hyper Wash and a decontamination using Nanoskin's fine-grade wash mitt, this is the damage that I found:
Untitled by The Critic, on Flickr
Interestingly enough, the owner had no specific concerns regarding the condition of his paint. But needless to say, the paint's condition had to be improved before I coated the vehicle.
For compounding, I used Meguiars M100 and a Rupes yellow foam polishing pad on the Rupes LHR21 for the hood, roof and fenders. This combination finished fairly well but sometimes required multiple passes to obtain the desired results. In the interest of efficiency, the rest of the vehicle was corrected with a Flex PE-14 rotary. On the sections that were done with a rotary, I used Meguiars M100 with a Meguiars WRFP7 pad to compound, but followed up with Meguiars M205 with the same pad to refine.
For final polishing, the entire car was finished down using the new CarPro Essence on the Rupes LHR21 DA with a foam polishing pad. After polishing, two coats of CQuartz TiO2 (Classic) was applied. Here's a picture of the coating being applied onto the vehicle (it had just been applied and was beginning to "flash"):
Untitled by Michael Wan, on Flickr
This was my first time using CQuartz TiO2. So far, I like it more than UK because the application process is a bit easier. The gloss is also a bit better and there is less darkening of the paint. The only downside is that 2 coats are recommended, so the amount of product used is much higher (I used about 35ml on this car) and the time commitment is far greater (about 4 hours to apply two coats).
And this is the final product (went back 2 days later to take these pictures):
2 by The Critic, on Flickr
3 by The Critic, on Flickr
I think the total time spent was about 15 hours. The owner is now in possession of a wash kit containing rinseless wash, proper towels, grit-guard, etc -- so hopefully this car will stay in good shape for a while. The paint is fairly soft but the coating should help reduce some of the wash-induced marring.
- TC
Re: 2015 Avalon - 2-Step Correction, CarPro Essence and CQuartz TiO2
Beautiful work Mike! That paint was in dire need of your attention.
What was used on the tires and trim?
Thanks for sharing.
Nice job. Isn't Classic SiO2?
Great work Michael. The flake looks amazing on that car now. Hopefully he takes the time to maintain it and doesn't destroy your work.
2019 Nissan Rogue SL
Thanks!
Thanks for sharing.
The trim was not worked on. Tires saw CarPro PERL at full strength.
The most recent revision of Classic contains TiO2. I believe the new name for the product is CQuartz TiO2.
Very nice work! A great turn around!
Scott Harle
Autodermatology
#autodermatology
By davidk72008 in forum Show N' Shine
Last Post: 02-03-2020, 06:15 PM
By The Guz in forum Show N' Shine
Last Post: 07-05-2018, 09:50 PM
By jonathanss in forum Show N' Shine
Last Post: 03-18-2018, 10:27 PM
Last Post: 02-02-2017, 02:13 PM
By Blackdevil77 in forum Auto Detailing 101
Last Post: 08-14-2016, 12:43 PM
