Originally Posted by abrcrombe
How do you get it done then Justin? You must be a magic man!
LOL!!!
- I use a swirl remover. #82,#80, #9 etc. Usually with EDGE 2K Yellow pad set at #5.
- Next, I use a glaze, if needed, like #7 or #3. I normally skip this step if I use #80, it has polishes and oils built in. Also only do this if the customer is wanting to pay for this extra step. I charge 50.00. I like to use EDGE 2k Blue pad set at #3.
- I top the 2nd step with 2 coats of NXT Liquid Tech Wax. I use the EDGE 2K White Finishing pad since it lays down and nice THIN coat. I let the first coat sit and dry for 30 minutes remove by hand. Here's a MUST for NXT. 2nd coat, let dry for 30 and remove by PC (G-100 in my case) with MF bonnet set at #5. This where I get a major color depth.
- For the ultimate protection and POP, I finish up with coat of #26 Yellow Wax. This is the best 10 bucks you'll ever spend. Using the EDGE 2K White Pad again (they are 2 sided!!!), I lay it down with a #3 setting letting it work into the paint. I let dry for ONE hour and remover with a MF bonnet at the #5 setting. I now finish up with a Final Inspection wipe-down.
Thanks guys.
Hopes this any good to you.
Justin
Very nice! How do you persuade them that a glaze is worth 50 bucks?! And what we were wondering is, since NXT has cleaners, doesn't it clean the previous layer that you just laid down? 2 sided edge pads sound VERY nice.
By KMG in forum Show N' Shine
Last Post: 05-05-2015, 09:08 AM
By SATracker in forum Show N' Shine
Last Post: 06-21-2011, 05:17 PM
Last Post: 01-31-2011, 07:51 PM
By Petrucci_M3 in forum Show N' Shine
Last Post: 03-27-2008, 05:26 AM
By pirex in forum Show N' Shine
Last Post: 07-04-2007, 07:56 PM
26 | 27 | 28 | 29 | 30 | 31 |
