Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 7 of 7
Hybrid View
  1. #1
    Newbie Member
    Join Date
    Apr 2015
    Posts
    10
    Post Thanks / Like
    what do i use on motorhome
    How do i solve this. The cover over winter has caused it and was thinking using meguires swirl x or am i best just sticking to a good polish and doing it a few times.
    Attached Thumbnails Attached Thumbnails what do i use on motorhome-img_5213-jpg
  2. #2
    Newbie Member SyntheticAtmosp's Avatar
    Join Date
    Apr 2015
    Posts
    18
    Post Thanks / Like
    Re: what do i use on motorhome
    Are you referring to the black streaks going down the side? That's contaminants on the water as it runs down. I don't cover mine and i get the same problem. Use pledge to remove it. I'm not joking, it comes right off. This year I plan to collonite mine to see if that will slow the build up.
    fapatalk
  3. #3
    Newbie Member
    Join Date
    Apr 2015
    Posts
    10
    Post Thanks / Like
    it may not be clear but a lot of dullness and then a shiney bit like shading a long the sides. i did polish it and it brightened up a tad but still this shady look. The cover only done this this year as no longer sheltered either side in a yard.
  4. #4
    Super Member davidc's Avatar
    Join Date
    May 2007
    Location
    Arizona
    Posts
    1,499
    Post Thanks / Like
    Now there are 2 threads on this. Looks to me like a compounding is due as oxidation has set in. A rotary, wool pad and start with a mild compound and see how it goes before moving up to heavier compounds. Be prepared as it is a lot of work to compound and apply LSP from beginning to end. I know I had well over 40hrs. beginning to end.
    Dave
  5. #5
    Newbie Member
    Join Date
    Apr 2015
    Posts
    10
    Post Thanks / Like
    It took me about 4 hrs jus to polish the side lol think it will be a long weekend and maybe week too.
    I have SwirlX and ultimate compound so will try swirl first as very mild and see how it goes first.
    Thanks David
  6. #6
    Join Date
    May 2007
    Location
    Arizona
    Posts
    1,499
    Post Thanks / Like
    Quote Originally Posted by Yellotaxi View Post
    Thanks David
    Save you a step, forget the swirlx. Gel Coat is some very stout stuff. Start with the Ultimate but from what I see you will probably need to move up from there.
    Dave
  7. #7
    Newbie Member
    Join Date
    Apr 2015
    Posts
    10
    Post Thanks / Like
    I will try a section and see how i go with both and see if results are noticable with each product, if not will see whats recommended. maybe beyond my knowledge and little expertise tho
Similar Threads
  1. Motorhome needs some work
    By iggy in forum RV & Motorhome Detailing
    Last Post: 10-30-2016, 10:29 PM
  2. Motorhome cleaning??
    By Yellotaxi in forum Ask your detailing questions!
    Last Post: 04-17-2015, 03:03 PM
  3. Motorhome protection
    By bigirn in forum Auto Detailing 101
    Last Post: 03-12-2015, 06:34 PM
  4. Detailing a motorhome
    By OCD Detailing in forum Auto Detailing 101
    Last Post: 02-03-2015, 04:25 PM
  5. Class A Motorhome
    By Znig22 in forum Show N' Shine
    Last Post: 10-30-2013, 12:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
