Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
  1. #31
    Regular Member 11B250's Avatar
    Feb 2015
    Palm Beach County, FL
    155
    Re: RUPES Pad and Compound Recommendation Charts
    Even though I don't own any rupes products, this was great info!
  2. #32
    Super Member Dylan@RUPES's Avatar
    Oct 2015
    215
    I have heard some experienced marring with the white Rupes pad. Sure enough, on this chart, it's not listed as a recommendation on soft paint. What is it about the white pad that may cause marring?
    Its a problem that can actually manifest with really fine pads of all makes when used on the right (or in this case wrong) paint. If we think of it purely in terms of porosity the finer the foam the more foam is actually in contact with the surface (less pores) so you're increasing contact surfaces... with some paints this can lead to issues like light hazing or marring. Seems counter-intuitive, but when I've encountered this issue going UP a notch to the yellow pad has alleviated some or even completely eliminated the issue. Its one of the weirder phenomena I've ever encountered in polishing and its rare I see it, but it does happen.
  3. #33
    Nov 2009
    Pasadena, CA
    12,615
    Quote Originally Posted by Dylan@RUPES View Post
    Thanks Dylan, great explanation!
    I just ordered UHS and yellow pads along with their polishes.
    '03 Corvette Z06
  4. #34
    Nov 2009
    Pasadena, CA
    12,615
    Are all the Rupes foam pads open cell?
    '03 Corvette Z06
  5. #35
    Jan 2017
    I just came across this thread after searching google for rupes pad chart. I wanted to see which pads I should use and in which order. I have an Infiniti with "Scratch Shield" self-healing clear coat. I believe that it is very soft as it scratches extremely easily. Just touching the paint with your finger will leave a mark. I was using the white pad with Adams Fine Machine Polish and I believe I was seeing the hazing. Switched to the yellow pad and so far it seems to be working much better. Once I use up my Adams polishes I plan on trying the Rupes Polishes.
    Thanks
  1. Recommendation for pads for Rupes Duetto
    By Chrisong in forum RUPES BigFoot Oribital Polishers
    Last Post: 08-07-2019, 08:32 AM
  2. Seeking Rupes Polisher Combo Recommendation(s)
    By Dan Tran in forum RUPES BigFoot Oribital Polishers
    Last Post: 02-10-2016, 01:00 PM
  3. Rupes Microfiber Cutting Disc with Rupes Zephir Gloss Coarse Gel Compound
    Last Post: 07-19-2014, 05:30 PM
  4. Compound Recommendation for Newb
    By G35 in forum Ask your detailing questions!
    Last Post: 11-24-2012, 02:02 PM
  5. First Cx Car + Compound recommendation
    By veeko in forum Auto Detailing 101
    Last Post: 10-07-2010, 03:30 PM
