Re: Need some new pads for the rupes
Originally Posted by Martiy
I just bought a Rupes machine and pads and about 3/4 the way through correcting the paint on the first vehicle both the blue and green Rupes pads started to separate and spewing chunks of foam all over. Granted I was using higher speeds; however I would think that they should last longer than one vehicle.
While intact the performance of the pads was fantastic, but overall disappointed.
The more they get chewed up the more wobble you'll get in the machine. I've used my UHS pads a lot and they were in pretty rough shape. I got one new one just to fill out an order and it runs super smooth by comparison, have 3 more on order now.
How many of each pad were you using to do the car?
The Lake Country HD Orbitals designed for the Rupes are top notch too. Only use the Rupes and LC HD Orbital pads as they maintain the balance while being vibration free which increases the machines longevity and user experience.
Thats likely the problem as I didn't switch out pads, just cleaned them on the fly with pinnacle cleaner and a light brush.
Just to comment....
The RUPES engineers designed their pads specific to the RUPES tools and backing plates for the intended purpose of reducing and eliminating vibration.
This means the size, shape, thickness and weight of the pads are such that when attached to the matching RUPES backing plate and RUPES tool there is zero or very little vibration.
I have demonstrated this to people simply by
First - Hold a RUPES polisher in the air with no foam buffing pad attached to the backing plate in the [ON] position on speed 6. You will feel the tool vibrating.
Second - Attach the correct size RUPES pad for the backing plate and matching RUPES tool and repeat the above. That is hold the tool in the air in the [ON] position on speed 6. You will feel no vibration and a very smooth operating tool.
Now after doing the above so you know what vibration feels like with no pad and what zero vibration feels like with the engineered pad, repeat the test with the pad you're thinking of using and see if there is any vibration.
- If no vibration, your choice, use or don't use the pad.
- If you feel vibration you will know it's the pad, not the tool.
I've done my research and real world testing and what I've experienced is that what RUPES states is true and that is they engineered their pads, backing plates and tools to work together to eliminate vibration.
This is an important benefit to RUPES to offer with their tools. Check with Todd Helme or Jason Rose if this is accurate or not.
Don't matter to me what pad anyone uses on any tool I just wanted to point out that when RUPES states their pads, backing plates and tools are engineered to work together to eliminate vibration they mean it.
I've always been what I call a "system guy" that is given the choice I prefer to use a system approach versus mixing and matching products, pads and tools from multiple brands.
I'm not saying mixing and matching doesn't work but I think you hedge your bet when you stay inside a system designed by the same company.
Here's a list I compiled of the dedicated RUPES classes I've taught and documented on this forum since Autogeek added the RUPES brand to the AG store and I'm here to tell you that when used as designed and intended, their system approach works.
All of the below cars were buffed out using the RUPES system as it was intended. This means RUPES tools, pads and products. The ONLY products NOT from RUPES would be the LSP's used as at the time I'm writing this RUPES does not offer any LSPs.
For the recored, when I was at RUPES in Milan, Italy as a guest speaker for their 2014 International Sales Meeting I strongly suggested they bring out three new products,
- A traditional carnauba car wax
- A synthetic paint sealant
- A paint coating
The reason why I recommended a product from each category was to give their customer base options and free choice. (we're all different). By offering RUPES brand waxes, sealants and coatings they can keep their customer base inside their line.
Because they don't offer these three types of products the FORCE their customer base to go outside their line to seal the paint. My guess is with the addition of Jason Rose to the RUPES team that this may change and I can't be the only one to see the lack of an LSP as a downside to what is a great line.
They should also bring out a one-step cleaner/wax like this one,
Jewelling Wax
I think this product would work well with the RUPES tools and pads and production detailing is the largest chunk of the detailing industry, not show car detailing. Guess we'll all get to wait and see what RUPES does into the future.
Here's the list of classes and cars buffed out using the RUPES paint polishing system since Autogeek bring in the RUPES brand.
List of RUPES BigFoot Detailing Classes at Autogeek
May 2013
Pictures: Detailing Boot Camp Class - May 4th & 5th, 2013
Training car: 1987 Buick Grand National
Special guests: Marco D'Inca Andreas Valentini
The person using the RUPES BigFoot in the below picture is the head engineer for RUPES - Marco D'Inca
September 2013
Rupes Detailing Classes at Autogeek!
Training car: 1963 Ford Galaxie Streetrod
This image has been resized. Click this bar to view the full image. The original image is sized %1%2 and weights %3.
January 2014
Pictures: Autogeek Detailing Class - January 2014
Training car: 1970 El Camino Streetrod with a 635 cubic inch Big Block Chevy
May 2014
Pictures: Detailing Classes at Autogeek - May 2014
Training car: 1964 Impala SS Convertible
September 2014
Rupes Bigfoot Polishers Detailing Class & Extreme Paint Restoration
Training car: 1967 Lincoln Continental Convertible with original single stage paint.
January 2015
How to use the Rupes Bigfoot Polisher - Detailing Class
Training car: 1962 Chrysler 300 Sport
May 2015
Removing water spots with Rupes Bigfoot 21 Orbital Polisher
Training car: 1955 Chevy Bel Air
July 2015
Car Detailing Classes - RUPES BigFoot Paint Polishing System
Training car: 1970 GTO Judge
compounding: Megs MF cut
one step polishing, finish polishing, AIO : Rupes yellow
my go to pad bin had only these 2 pads in it. there isn't a car i've done that this pad combo hasn't handled.
Thanks Mike, read your free air spin test above and rushed over to my Rupes. The 5.5" LC Flat pads displayed very noticeable vibration. The Rupes pads along with the LC HD Orbitals were vibration free! So my advice above was spot on
It's an interesting way to test compatible pads.
A great forum is made up of good people who freely help others reach their goals.
Spot on Mike.
The larger the stroke, the more sensitive the machine becomes to imbalance. The easiest way to test for this imbalance is to run the tools in free air.
RUPES is a tool manufacturer, that is we engineer and build the tools, not purchase them and slap a label on them. Since 1947, RUPES' reputation as an engineering firm and tool manufacturer in Europe has been beyond approach.
The original BigFoot Project was projected to take around 6 months to complete, but actually took almost 3 years. To ensure optimal performance and to elongate tool life, it is necessary to balance the rotating assembly completely. Not only is a large stroke sensitive to imbalance, but it is also damaged by it. Any vibration you feel in free air is side load on the bearing inside the tool (note: vibration is absorbed by the foam when applied to the paint BUT the imbalance is still loading the bearing).
Because we are the originators of large-throw tools and we engineered them over the course of 3 years, we understand how damaging this imbalance is. If it vibrates in free air, it wasn't designed by engineers.
Todd, I think most will get your point but I think you would better say it is as not as well engineered as Rupes (not no engineering vs engineering) if you are trying to say it is designed with no compromises on all aspects. Engineers can design any level depending on the job at hand.
In any engineering activity you can make compromises based upon project goals, and obviously someone can design to optimize some other aspect over another.
If two have two cars: one optimized for power (huge engine) and another optimized for a smooth quiet ride, the one that is considered better engineered depends on goals.
I do like the smoothness of my Rupes 15 but have not used any long throw.
Last Post: 01-03-2020, 11:12 AM
By joleyred in forum Auto Detailing 101
Last Post: 05-27-2018, 10:18 PM
By Crispy in forum Ask your detailing questions!
Last Post: 07-01-2016, 01:44 PM
By Elger in forum Wool & Foam Buffing Pads
Last Post: 06-21-2016, 09:32 AM
By rah28 in forum RUPES BigFoot Oribital Polishers
Last Post: 01-04-2016, 07:17 AM
