Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
    Aug 2013
    111
    Cutting power of the rupes?
    I want to purchase a rupes polisher. Still torn on the 15 or 21. Reading the posts fellow members have made has made this decision so hard. So many people have such good insight on each one. Since I still am torn on which one to get, my main question is will both of these polishers have more cutting power than the porter cable? I mostly use 5.5 inch pads except on the roof and hood of my car. I just want to speed up my detailing time a bit. I do other cars for friends and starting to branch out to other people for side jobs. I mainly just do 1 car a weekend for a little extra spending cash but need a way to speed up the time
    Super Member refreshauto's Avatar
    Feb 2014
    Odessa, TX
    1,158
    Re: Cutting power of the rupes?
    it is a night a day difference between the PC and the Rupes. i dont own, but i have used it, and the only thing i will tell you is that if you get the Rupes, get the complete system. get the machine, pads and polishes. use the system and you will see a dramatic difference from the PC
    Super Member VISITOR's Avatar
    May 2007
    9,774
    have you given the flex a thought as well? it has interchangeable backing plate system and you can use a variety of pads from 4"-6.5" to tackle every inch of the vehicle and did i mention it's a workhorse? there's pretty much nothing it can't handle, especially gieven the plethora of different pads and products out these days...
    Aug 2013
    Tustin, CA
    4,389
    Get a Flex 3401 VRG I still have my PC 7424 XP but use it very little. Once you get a Flex which is the ONLY FORCED ROTATION DA and more powerful than any other free floating DA...PERIOD. Once you try out a Flex 3401 VRG you will never go back to a free floating DA. Additionally, the Flex is less expensive, there are more backing plates for it, there are more pad options from 4" to 6.5" and you do not "eat" the pads that are not designed by Rupes. Every other pad not made by Rupes tends to either lose their backing or the pads get ripped because of the rotation being to aggressive for those pads.
    If it were me look into a Flex before spending $$ on a Rupes.
    I will probably cause a stink now, however, this is MY OPINION.
    Regular Member MNDSMtuner96's Avatar
    Sep 2012
    148
    Quote Originally Posted by Kamakaz1961 View Post
    Amen. Flex xc 3401 vrg! Love it!
    Sent from my SPH-L710 using AG Online
    Dec 2009
    CA
    673
    Rupes all the way. Once you master the operation of the machine, you will find that it will cut every bit as well as the 3401.
    The forced rotation of the Flex is way overrated. The complaints of lack of rotation on the Rupes are from people who are either using the wrong Rupes for the job, or have not learned how to properly use the machine.
    And this coming from someone who sold their 3401 and now has a LHR21ES, Duetto and 75e mini.
  7. Likes Joel1979 liked this post
  8. #7
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    Going from a pc, I'd recommend the Rupes. They are very smooth. However, if you ever plan on doing heavy correction or wet sanding, go with Flex. I personally like to have as many tools as I can to do whatever job arises. I have PC 7424xp, cyclo 2nd gen, GG 6, Makita 9227, Dewalt 849, Flex 3401, Rupes 15, Rupes 75 mini. Kinda like pads and micros, You can never have enough.
  9. #8
    Super Member spiralout462's Avatar
    Dec 2012
    Eastern Shore, VA
    1,771
    Quote Originally Posted by fly07sti View Post
    Which rotary do you use more often? Makita or DeWalt?
  10. #9
    May 2007
    9,774
    i disagree. i love and still use my DA's (GG6, G110) and wouldn't be without them. everyone should own at least one traditional style DA, it's versatile and can be used in many different situations. yes, you're entitled to your opinion as am i...
  11. #10
    Super Member Tato's Avatar
    Nov 2013
    Brazil
    2,157
    My suggestion is for you to take a look at an answer I wrote on using the Rupes 21 and the Flex 3401 regarding use of Rupes pads and Menzerna polishes (included many pics).
    http://www.autogeekonline.net/forum/...ml#post1114980
    Cutting Power? Impressive. The tool is a pleasure to use. But you have to work your way to learn using it properly, to achieve optimum results.
    I'm not ashamed of assuming I've faced pad stalling even on flat panels on my first passes, totally my fault. Work your way to perfect technique, and you'll be amazed like I am. I can't stress enough how much I've liked the Rupes mechanism.
    But I still have the Flex, and use it always as well.
    Best wishes, good luck on your search.
    ― Isaac Newton
  1. Question about cutting power
    By boradori007 in forum Auto Detailing 101
    Last Post: 07-24-2017, 03:36 PM
  2. Next step up in cutting power
    By FA22raptero in forum Auto Detailing 101
    Last Post: 08-05-2016, 04:04 PM
  3. Rupes Microfiber Cutting Disc with Rupes Zephir Gloss Coarse Gel Compound
    Last Post: 07-19-2014, 05:30 PM
  4. Cutting Power For Gel Coat
    By TuxedoTaurus in forum Boat & Marine Craft Detailing
    Last Post: 06-05-2014, 09:05 AM
  5. 205 and optimum II no cutting power
    By frankprozzoly in forum Auto Detailing 101
    Last Post: 05-31-2014, 03:00 AM
