Re: is the Rupes LFR75E really worth $200 more then GG3"
Originally Posted by KMG
Yeah I was doing some reading and saw a lot of people commenting about needing to use it on speed 6 to do anything with it, which is why I started looking at the Rupes as another option. Plus I like how all the other Rupes require little to no pressure for correction. Is this an issue that you have notice with your GG also Evan?
I always use speed 6 on my GG3 I don't see it as an issue just what you have to do with the machine if you want it for correction. They only time I use a lower speed is when I'm applying a wax with it.
I am looking to pick up a 3" unit next month and was planning on getting the GG 3" unit, however I have been reading that it is pretty slow working and requires a lot of pressure to make it work correctly.
The Griot's Garage 3" Mini Polisher is nice because of it's size. It is the small size that makes it convenient and useful for working tight areas and thin panels.
I use this tool mostly for machine wetsanding and machine applying waxes.
Sanding
With a 3" sanding disc you can SAFELY,
1. Sand thin panels: Sand right next to an edge because the tool is easy to control --> by this I mean move next to an edge without sanding over the edge. You can't do this with 5" and 6" sanders.
2. Sand into tight areas.
3. Learn how to machine sand. If you're new to machine sanding it's easier to get the hang of it with a small sander than a larger sander.
Machine wax
The Rupes 4" white finishing pad fits the GG 3" polisher and the small 4" Rupes pad is soft so it compresses easy and this means you can squish it into most wax jars to get wax instead of removing the paste wax out of the jar or using a knife/spatula/PC Wrench to get the wax out of the jar and onto the pad. (Of course I'm talking about paste wax use as with a liquid you could just squirt some on the paint or on the pad).
I almost always apply any liquid or paste wax or sealant by machine. The ONLY time I apply anything by hand is if I HAVE to. (That's just me though...)
How does the Rupes compare in these situations, and factoring in price is the Rupes really worth the extra $200?
Technique is important with both tools. That is in order to maintain pad rotation you have to pay attention to what you're doing. Mark your backing plates with a permanent marker like I show in my article here and then hold the body of the tool so the pad is flat to the surface.
I have used both tools a lot. I have always used either one or the other so I have not had them in use at the same time which is when you would compare them. That is keeping as many controls in place as possible so the only variable is the tool itself.
Originally Posted by runrun411
I have a GG3 and it's only as good a speed 6. Seems like it doesn't do anything on any of the lower settings.
It's only good for correction work on the 6 setting.
For machine sanding you can go as low as the 2 setting as long as you see the pad rotating.
For machine waxing the 4-5 setting is fine, you don't need to be on the 6 setting to spread out a thin coat of a finishing wax or sealant.
Agree...
I've been using my PCXP for a while with the 3 inch backing plate and pads and it works excellent. I will eventually upgrade to the Rupes but it just doesn't seek necessary at this point.
Sent from my DROID RAZR using AG Online
Mike,
Thanks again for the input. I am thinking that for the time being I am just going to stick with getting the GG3 as it will see limited use as compared to my large DA which I am also upgrading. If after this year I notice that I am using it a lot and there is more info and reviews out on the Rupes Mini then possibly next year I will check into upgrading.
Thanks for all the input guys.
Mike I could not agree more. I did not regret purchasing the pe-14 last year when I came out to visit nick and the Autogeek facility. I feel like people are always turned off by this machine because it's a rotary and there is a learning curve.
The Mini combined with Rupes microfiber pads is a wicked combination. I love mine
It comes down to your preference
I am in mechanicsburg,if you you want to borrow mine and try it out first you are more than welcome to. I have the Rupes smaller. MF pads you can try out on it ,and some foam. A friend of mines dad lives in Lebanon also if you can't get out here I am sure he would drop it off for me. But I am right by the Wegmans on the Carlisle Pike if you wanna test run it for a week or 2. I had the GG3 and for MF pads my opinion is it sucked,but that's just me.
Matt
I was actually thinking about comparing the power of my 75e vs my GG3. But I ended up selling the GG3 (finally). Been trying to sell it for some time now.
I literally used it once and decided it was useless and put it up for sale.
The 75e has MUCH more power. It's def worth the $200 markup. I'm not even going to bother comparing them anymore. The 75e is just better... And it should be for the price.
By DaveJustDave in forum Auto Detailing 101
Last Post: 10-19-2018, 07:43 AM
By Mike Phillips in forum RUPES BigFoot Oribital Polishers
Last Post: 01-22-2017, 10:37 AM
By expdetailing in forum RUPES BigFoot Oribital Polishers
Last Post: 12-02-2014, 11:52 AM
By Mastercraft241 in forum Product Reviews
Last Post: 04-24-2014, 12:56 PM
By pcw25 in forum Auto Detailing 101
Last Post: 12-09-2011, 03:33 PM
