Results 21 to 30 of 31
  1. #21
    SELF BANNED
    Sep 2017
    570
    Re: Need Advice - Rupes Mille vs LHR15 Mark II
    Quote Originally Posted by hammargren View Post
    I do know a lot of people I have spoken strongly of the Mille and said it’s a very user friendly tool. I don’t think I could have gone wrong with either the Mille or LHR15 but choose the gear driven after many suggestions and speaking to people. Hopefully made the right choice
    Well said. Also I think its Mike Phillips who stated instead of saying which polisher should I get, it should be which polisher should I get first.
    I own all Flex/Rupes/DAS(Griots) types polishers and the three most used are the Mille, 21 MKII with 5” bp and Mini.
  2. #22
    Apr 2015
    Re: Rupes Mille vs LHR15 Mark II
    I have the Mille and its a beautiful machine, you will love it.
  3. Likes Lumorales1975 liked this post
  4. #23
    Nov 2014
    149
    Mille churns and burns!
    I love the pressure you can put on it to remove stubborn defects.
    Used mine again today alongside my 21mk2 and PE14 rotary to knock out a pretty serious compounding step after wet sanding!
    Mille is a great tool, and a lot more smooth than what you may expect from a gear-driven orbital!
    Brandon Visser | 269-569-1900 | b5visser@live.com
    Owner/Appearance Specialist | @domainappearance
  5. #24
    Junior Member hammargren's Avatar
    Oct 2011
    ND
    49
    Excited to get mine and learn how to use it
  6. #25
    Junior Member desidetailer's Avatar
    Jan 2018
    Chandigarh, India
    43
    Bumping up this thread Again.
    I use a rotary (makita 9237c) and mini polisher(shinemate ex603) now was planning to add a polisher to finish better. So firstly thought 21mk2 with 5" bp but then thought 15mk2 as it will finish better and more verstile... now wondering if mille can serve better purpose keeping prices of both these are same and mille being latest tech... I really dnt have any idea of these dual purpose machine... so far my main purpose is better finish, final finish but if really liked you never know I end up making it as my main tool for correction as well...
    P.S:- Is there any near plan of rupes to bring mk3 after this sema?
    TIA
  7. #26
    Junior Member gsmarquis's Avatar
    Apr 2018
    64
    The backing pad on the mille is held on with screws recessed from the pad face into the machine? Does that have risk of a screw vibrating out and falling on the panel surface?
    I just have a 3" Griot's and a HF 5" setup. Looking to buy a quality unit. I have heard Rupes is it. The above screw thing is kinda messing with me.
  8. #27
    Super Member Dan Tran's Avatar
    Sep 2015
    Portsmouth, NH
    1,055
    I have never used the Mille...
    But the LHR15 Mark II is a PHENOMENAL machine.
    It’s my favorite machine of the entire lineup!
    It’s a very well-rounded tool assuming it’s my one and only machine. Also it’s very capable at defect removal.
    A very safe machine. Slight learning curve, but easy to learn the technique involved.
  9. #28
    Jan 2018
    Chandigarh, India
    43
    Quote Originally Posted by gsmarquis View Post
    Nothing like that, rupes won't design it with such silly problem and so far no one had this issue. Although many member here wants/recommend changing screw to allen screw as they find it easy to swap plates, better to work and safe..
  10. #29
    Apr 2018
    64
    That's what boggled me about the screw thing. Would not think they would have designed it like that. I miss understood someone describing it to me. I don't mind spending 300-500 on a machine, I just want high quality and longevity.
  11. #30
    Super Member Rsurfer's Avatar
    Jan 2007
    14,096
    Have not seen the Mille, but doesn't your pad cover the backing plate? If so, how can a screw if it should come loose bypass the pad?
  1. Rupes LHR15 Mark II, for cutting?
    By braga in forum RUPES BigFoot Oribital Polishers
    Last Post: 03-17-2019, 10:21 PM
  2. Rupes LHR15 Mark II stall
    By ARTB155 in forum RUPES BigFoot Oribital Polishers
    Last Post: 09-18-2018, 12:42 PM
  3. Rupes LHR 15 mark 2 vs Mille
    By Johnydamouni in forum Ask your detailing questions!
    Last Post: 10-26-2017, 12:32 PM
  4. Rupes Mark 1 LHR15 question on rubber top mount
    By kevinmfitz in forum RUPES BigFoot Oribital Polishers
    Last Post: 08-19-2017, 05:54 PM
  5. Review: Noob gives Rupes LHR15 Mark II HD Version a shot
    By BudgetPlan1 in forum Product Reviews
    Last Post: 12-28-2016, 10:27 AM
