Rupees polishing pads
Happy New Year to you all.
Im looking at buying a Rupes polisher or two. I have a dumb question for all the experts that use this brand.
can the Rupes pads be washed and reused or do you throw away afterwards?
here In New Zealand we have to use Rupes pads and Polish for a one year warranty on the machine witch I think is load of rubbish.
Brendon
HAPPY NEW YEAR
Re: Rupees polishing pads
Can be reused after washing. The thing with Rupes pads is use a few and change often as they not durable at all. The GG,LC,BnS last much much longer and are cheaper. Really hope 2017 Rupes changes their foams as its long overdue.
Brend
HAPPY NEW YEAR
Buy a flex 3401 much better machine in my own opinion.
Brendon
HAPPY NEW YEAR
How would they know that you didn't use their pads and polishes?
That's what I was wondering. I guess you would have to buy a few pads and a couple bottles of polish...then use whatever you want. If there's ever any question you bought some of their products so your covered.
2015 F-150 Crew Cab Lariat
2016 Chevrolet Camaro 2SS
They can be washed out and reused. If you have UHS pads the best way to wash them is under warm water.
Wash and reuse. I like their yellow and white pads. The blue and green, not so much. Go with the Rupes microfiber pads for cutting and finish with the yellow and white. And if that is truly Rupes policy there, complain loudly. I use many different manufacturers pads with my Rupes machines with no problems.
Wash and reuse.
Rupes blue microfiber, yellow foam, white foam. These are my 3 go-to pads that i use nearly everyday.
The UHS pads are a bear to clean,if they didn't work so well,I would try something else
Like others mentioned here, I use the blue and yellow microfiber pads / yellow, and white foams for the most part.
I had some blue foam pads, and they were awesome! Somehow, I convinced myself to sell them, and now I have to replace them....
I say get a couple.
Be warned that you will find best results using the system like they advise. You might see the blue foam deteriorate as you learn to keep the pressure off. I know mine started to wear away after a few uses, but nothing catastrophic. I also had the backing on a couple yellow pads weaken. The foam was in great shape though.
I have decided that I will be rounding out the system and adding Quarz/Green pads, UHS system, and replenish the blue foam pads that I sold as the busy season approaches.
I'm going to try to exclusively use the Rupes system starting January 1, 2017.
By Joe@NextLevelDetail in forum Auto Detailing 101
Last Post: 06-26-2019, 06:14 AM
By tattooman in forum Auto Detailing 101
Last Post: 12-26-2017, 05:16 PM
By coupe07 in forum Wool & Foam Buffing Pads
Last Post: 05-15-2015, 08:21 PM
By dlc95 in forum Wool & Foam Buffing Pads
Last Post: 01-06-2015, 09:54 PM
By Justin in forum Auto Detailing 101
Last Post: 07-19-2008, 07:30 AM
