Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
  1. #41
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    Re: LHR15 Mk II + Duetto + Mini = Overkill?
    Quote Originally Posted by Joel1979 View Post
    Zubair let us know how 21 compared against rotary.
    Im sure Duetto can do that. My test hood is e34 bmw metallic blue and my 21 removed p1500 effortless using mf pad and compound. I only did 4 overlaps and it was ready for finishing and Diamond gloss with white pad was enough to remove microfiber haze. Sometimes i wonder who needs a rotary these days
    And, again, just to be clear- you're adding some pressure too?
    Are you/have you used Zephir?
  2. #42
    Aug 2016
    199
    Yes i use moderate pressure, not too much at all. I tested M101, Zephir, S3 XXL and Nanolex heavy cut. They all did the job.
  3. #43
    May 2013
    Rochester Hills, Mi
    6,016
    Thank you!
  4. #44
    Super Member BudgetPlan1's Avatar
    Dec 2015
    Central OH
    2,000
    Quote Originally Posted by Zubair View Post
    The washer mod seems to make a larger improvement on the MKII's than the MKI, then ofcourse Kamikaze takes it up yet another level.
    Waiting for the Kamikaze Beast plate to become avaliable/in stock for the LHR15 Mk 2...that'll be interesting.
    Sent from my SGH-M919 using Tapatalk
  5. #45
    Sep 2016
    89
    Pulled the trigger on Duetto mainly for form factor reason and don't have big panels for LHR21. I will sell the mini if I find it redundant. Also, purchased Makita XBU02Z cordless blower.
  6. #46
    In time out
    Sep 2014
    Johannesburg,South Africa
    1,631
    Will do, the car is supposed to have arrived 20 minutes ago already.
    Quote Originally Posted by BudgetPlan1 View Post
    The 15 uses the Kamikaze Katana, the 21 and Duetto use the Beast.
  7. #47
    May 2013
    Rochester Hills, Mi
    6,016
    Quote Originally Posted by cay7man View Post
    You'll probably still want to hold on to the Mini. There are a lot of places you can go with the Duetto, even with finesing the pad edge. They're made easier with the Mini.
  8. #48
    Dec 2015
    Central OH
    2,000
    According to US distributor, 15 Mark 2 is Beast, legacy 15 is Katana.
    KAMIKAZE 5" BEAST BACKING PLATE FOR THE RUPES LHR12 DUETTO, LHR15 MARK II, AND LHR21 BIGFOOT POLISHERS!
    The Kamikaze BEAST 5" backing plate for the Rupes LHR12 DUETTO, Rupes LHR15 Mark II, and LHR21 Bigfoot provides the ultimate in performance, precision, balance, and smoothness!
    NOTE: This backing plate is designed only for the LHR12 Duetto, LHR15 Mark II, and LHR21 Bigfoot, and not the LHR15ES. While it will fit, the balance will be off, and you will not achieve the highest level of performance. For your Rupes LHR15ES Bigfoot, you want to use the 5" KATANA backing plate.
  9. #49
    In time out
    Sep 2014
    1,631
    And according to my UK source its still the same on Legacy ES and MKII models. However I have the new revised MKII Katana and Beast plates with cooling holes.
    Edited to add: Tried Katana and Beast on both 21 and 15 MKII now. Katana doesn't play well on the 21 MKII but both Katana and Beast work fine on the 15 MKII.
  1. Will the LHR15 front housing fit the Duetto
    By Whitewater25 in forum RUPES BigFoot Oribital Polishers
    Last Post: 04-30-2018, 06:28 AM
  2. RUPES Lhr15es mk11, mini or duetto
    By Jmbrown415 in forum Auto Detailing 101
    Last Post: 01-07-2018, 12:13 PM
  3. Rupes Duetto And Mini - Kit?
    By dlc95 in forum RUPES BigFoot Oribital Polishers
    Last Post: 08-14-2014, 06:44 AM
  4. Those who have or are buying a Rupes Duetto, LHR15 or LHR21....
    Last Post: 04-28-2014, 10:28 AM
  5. PRE-ORDER: Rupes LHR 12E Duetto & LHR 75E Mini Polishers!
    Last Post: 12-05-2013, 11:34 AM
