Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    Re: LHR15 Mk II + Duetto + Mini = Overkill?
    Excellent follow up!
    Those white LC Polishing pads have both closed and open cells. Just to let you know that they won't dissipate much if any heat. I did successfully use some Tangering LC closed cell pads on a Duetto, and Menzerna PF2500, but I was in constant concern I was going to blow them up.
    HateSwirls actually went from a 3401 to a LHR15ES, or it might have been the MKII - I don't remember. Regardless, it seems to get work done well for him.
    Sep 2016
    89
    Relevant to the subject of this thread - I've a Rupes mini and 7424. Thinking of replacing the 7424 with Duetto. Should I go for LHR15 instead?
  3. #13
    In time out
    Sep 2014
    Johannesburg,South Africa
    1,631
    Quote Originally Posted by cay7man View Post
    The 15ES and the Duetto are very similar in smoothness and speed of correction. The decision will come down to which form factor you prefer. Having already owned a PC and a Mini why not try something different?
  4. #14
    Sep 2016
    89
    Quote Originally Posted by Zubair View Post
    Zubair - actually, I'm just getting started on detailing. I got the PC long time ago for actually polishing granite counter tops at home but never used it. huge difference between 15ES and Duetto? For which one mini is good companion?
  5. #15
    In time out
    Sep 2014
    1,631
    A companion to the mini would be a Rupes 21, that way you have all bases covered.
  6. #16
    Sep 2016
    89
    Ok, thanks!
  7. #17
    May 2013
    Rochester Hills, Mi
    6,016
    I'm a big fan of the Duetto.
    I borrowed a fellow local detailer's 21 last week, and while I thought it was insane how far it got that pad to orbit, I didn't like the long, rotary style chassis.
    If they would make a 21mm Duetto, I'd be very interested.
    But for now, I'm very happy with the one I have.
  8. #18
    Aug 2016
    199
    I have 21 mk2, 15mk2 , duetto and mini. 21 is by far the best machine, i can use both 5" and 6" pads and it is much more powerfull than my 15 mk2. I think im going to sell my 15 mk2, even my duetto outpowers it.
  9. #19
    Apr 2015
    PGH, PA
    1,482
    Wouldn't both of those options be extremely similar? Why get both?
    Sent from my iPhone
    There's going to be times/areas where 8mm will do better then 12mm
    Plus it's cheaper trio, can use it for the wax spreader and leave the other two strictly for paint correction
  10. #20
    In time out
    Sep 2014
    1,631
    Quote Originally Posted by Joel1979 View Post
    Hasn't your 15 MKII proven to be faulty and repaired/replaced under warranty? None of my polishers stall that easily. My 15ES and 15MKII both have massive pad rotation and none have that issue you displayed in your video. I do agree the 21 MKII is the most powerful though, its quite evident when I compare it to my 15 MKII.
  1. Will the LHR15 front housing fit the Duetto
    By Whitewater25 in forum RUPES BigFoot Oribital Polishers
    Last Post: 04-30-2018, 06:28 AM
  2. RUPES Lhr15es mk11, mini or duetto
    By Jmbrown415 in forum Auto Detailing 101
    Last Post: 01-07-2018, 12:13 PM
  3. Rupes Duetto And Mini - Kit?
    By dlc95 in forum RUPES BigFoot Oribital Polishers
    Last Post: 08-14-2014, 06:44 AM
  4. Those who have or are buying a Rupes Duetto, LHR15 or LHR21....
    Last Post: 04-28-2014, 10:28 AM
  5. PRE-ORDER: Rupes LHR 12E Duetto & LHR 75E Mini Polishers!
    Last Post: 12-05-2013, 11:34 AM
