Re: iBrid Owners - Questions here...
The blue pads suck and I love Rupes products. Throw them away and buy some microfiber pads from LC or CarPro or cut down some Meg's pads. The blue pads suffer from the same open cell problems as the 6 and 7 inch Rupes regular blue pads. The Polish is good though.
It's a waste of time trying to use the adhesive sandpaper to sand headlights. The paper is used for denibbing or tiny spot correction. I hope you did not buy the Nano just to use on headlights. You would have been better off buying the Rupes Mini and buying 3 inch sanding discs.
The nano is a great tool but it's not made for newer detailer.
Love the brush set up doing mats real quick and interiors except leather.
Originally Posted by GSKR
virtually impossible doing headlights with that,especially wet the disc flys off the machine.
That answers that. I usually sand by hand but was curious. Doesn't appear the sanding discs will have much use then.
Sad to hear. Second part of the full kit that doesn't appear to have much use.
It's a waste of time trying to use the adhesive sandpaper to sand headlights. The paper is used for denibbing or tiny spot correction. I hope you did not buy the Nano just to use on headlights. You would have been better off buying the Rupes Mini and buying 3 inch sanding discs. The nano is a great tool but it's not made for newer detailer.
No I didn't buy it for headlights. I bought it for small / tight areas as a polisher vs doing them by hand. I normally sand headlights by hand as it doesn't take much. I hit them with 1500 then 3000 then polish. They are pretty simple but was just curious if it would work. Overall, I've been detailing cars for over 25yrs just not for money until about one year ago.
I'm glad to see others have the same feelings about the Rupe's Blue pads. I was criticized for questioning the bigger pads earlier.
That's disappointing to hear overall. I'm going to try them with various products of course but at the same time investigate options in order to be prepared to replace them. If the yellow work well as others said, that's a good thing. The white ones I'll likely order to try out. Sanding disc wise, it may not be something I can use then as I don't do any fresh paint work nor do I think I need any motorized sanding on any other paint. Scratches I tend to tape off and hit by hand given the danger of damaging the clear. I feel I have scratch removal and blending of touch up down-pat and get get nearly 95-100% blend pretty easily.
In the effort to get my TA's completely dialed in, I have been using the long neck with 1" yellow pads & Keramik on the tail lights to eliminate swirls. As an alternative, I tried a blue 1" pad with the Zephir polish. Absolutely no difference in swirl removal. They both get the job done beautifully on the black plastic.
I feel the iBid is an amazing tool. But I would like to see a plane jane kit. Just the actual tool, backing plates, battery, and charger. I don't need the pads, towels, polishes, bag, or brushes.
Carolina`s Finest Detailing - Charlotte areas preferred CQuartz Finest Reserve & GTECHNIQ Crystal Serum Ultra coating center. STEK/Suntek PPF
www.Carolinasfinestdetailing.me
Well I've come back to say that after a handful of weeks practicing and using the unit for details that I'm happy. Much more so than initially. It definitely takes a very light touch and consistent focus on keeping the pad flat. I have since used it to spot-correct several areas on my wife's van whereby I can tell she's rubbed it hard with her purse likely exiting the vehicle in the garage. She has a tendency to park too close to the wall in fear of hitting my car. LOL though as there's like 2-3ft between mine and hers if she parks it correctly.
I'm anxious to try the 1 & 2" Lake Country force pads on mine,just need the rain to quit.
I'll be interested to see how they work.
2015 F-150 Crew Cab Lariat
2016 Chevrolet Camaro 2SS
By Justin at Final Inspection in forum RUPES BigFoot Oribital Polishers
Last Post: 02-24-2019, 05:52 PM
By skipper1 in forum RUPES BigFoot Oribital Polishers
Last Post: 06-26-2018, 09:22 AM
By Mazo275 in forum RUPES BigFoot Oribital Polishers
Last Post: 06-01-2018, 09:53 AM
By Pats300zx in forum Auto Detailing 101
Last Post: 04-11-2018, 01:19 PM
By jonn127 in forum How to make money detailing cars
Last Post: 08-03-2014, 10:20 PM
