Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Aug 2016
    Montana
    32
    Question 21 Mark II with 5 inch BP?
    Has anyone used a Rupes 5" backing plate on the Bigfoot 21 Mark II? If so, how do you like it? How does the machine behave with the smaller bp? What is Rupes official stance on this mod?
    It would be nice to have the option of using 5.5"/6" pads for smaller panels where the 7" pads can be cumbersome. Definitely wouldn't want to risk damaging the buffer if the smaller bp puts too much stress due to higher rpms.
    Dylan: Your thoughts on whether you think this is a good or bad idea very much appreciated.
    Apr 2012
    7,494
    Re: 21 Mark II with 5 inch BP?
    Lot's of posts on this subject try the search feature, Dylan has also already commented on this subject. Search Rupes Mark II
    2019 Nissan Rogue SL
    Apr 2012
    7,494
    I just did a quick search Rupes Mk II and found this
    5" backing plate on the lhr21 mark 2
    There are more, search is your friend
    Aug 2016
    Montana
    32
    Thanks, didnt see that thread searching Google.
    Apr 2012
    7,494
    Quote Originally Posted by MTCarNut View Post
    AG's search, upper right hand side of this thread page, the white block.
    Aug 2014
    Brazil
    492
    I have a 21 ES, and when I put the 5in BP, it becomes a pad eater.
    Obviously increases cut, it is like a turbo mode, but a lot more vibration as well, especially sideways vibration.
    In mf pad, it generates such a heat that the pad's foam interface melts inside, like b&s black mf pad without center hole.
    The Rupes 6in pads on a 5in BP on a 21 becomes convexed, and the center hole opens up like a cone, if you insist in using it. The Velcro durability shortens as well.
    Rupes engineers were right when they decided the relation of offset and BP size, spot on.
    I'm considering buying a 15 MKII, so I can use 6in pads.
    Or buying a Chinese knock off, unfortunately, because a Rupes 15MKII will cost me 1000 bucks .
    Best regards
    Aug 2016
    Montana
    32
    Thanks, think I'll save and just get 15 mkII down the road.
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    Very good idea!
    Apr 2012
    7,494
    Quote Originally Posted by RPM_BR View Post
    Best regards
    Great post and feedback.
    The moral of the story, use the machine as it's manufacturer designed it to be used. Go outside their parameters and be prepared for the potential issues and don't complain to the manufacturer when the changes create said issues.
  10. #10
    Nov 2015
    Los Angeles, California
    13,817
    1 the main reasons I'm happy I ended up with a Boss G21.
  1. 5 inch backing plate for the Rupes Mark II LHR21
    By RMarkJr in forum Ask your detailing questions!
    Last Post: 03-22-2017, 06:14 AM
  2. Rupes Mark II , Mark ii NICE!
    By SonOfOC in forum RUPES BigFoot Oribital Polishers
    Last Post: 12-25-2015, 04:20 PM
  3. Flex Precision Pads 1 inch 2 inch 3 inch - IN STOCK
    Last Post: 10-28-2015, 08:56 PM
  4. Replies: 19
    Last Post: 02-16-2014, 11:49 AM
  5. 5 1/2 inch and 6 inch Buffing Pads - Pictures and Links
    By Mike Phillips in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 11-23-2011, 12:37 AM
